They are doing further testing, as some bundles are just hitting a wall beyond 4.4GHz irrelevent of voltages used which could mean some CPU's hit a wall at certain speeds or its something else holding back. As such bundles will be 4.40GHz from now on.
I understand your pain.
Real world difference between 4.6 and 4.4 is such a bummer...................
Real world any dual core will do...you are on the wrong forums fella.
Isnt sandy bridge a quad...
The current ones are quads or quads with HT.
The duals will be coming shortly...
actually smartass it means it can do a higher speed at lower volts guaranteed.the 4.4 cpu's are hitting a wall and not going past it.
u done trollin?
