Ok great, this is what i am currently running
Asus M2N-SLi Deluxe (Socket AM2) PCI-Express DDR2 Motherboard
AMD Athlon 64 X2 Dual Core 6000+ 3.00GHz (Socket AM2) - Retail
Corsair 2GB DDR2 XMS2-6400C4 TwinX (2x1GB)
Gainward BLISS GeForce 8800 GT 512MB GDDR3 HDTV/Dual DVI (PCI-Express)
Hiper 580W SLI Modular PSU.
Also i just bought a BFG GTX 260 OCX MAXCORE 896MB PCI-E which i have a slight problem with, basically it doesnt fit onto my motherboard properly, when i try to plug it in it hits a resister or component on the motherboard which stops it pluging all the way into the pcie slot.
My current set up is pretty good & i have no major problems but i would like alittle more Oomph for more recent games, Games is what the computer will be mainly used for.
I was thinking about a Quad core, maybe an Intel Q9550 2.8ghz, but im no expert & am not sure how much more powerful it would be than what im currently running.
So anyway i was willing to go upto maybe £400-£450, maybe alittle more if its worth it.
Any help & advice you can throw my way would really be appreciated.
