OcUK Clearance Section - Great Deals to be had!!
cheers
just realised this morning i had only an agp card for a pci-e only dfi mobo i picked up from the members market recently, so 6800gt pci-e on its way now hopefully - thanks!
What do you guys reckon of the AMD Athlon 64 X2 Dual Core 3800+ processor?
I am currently running a single core Pentium 4 2.4Ghz and was planning to upgrade to a C2D in the near future. Would the 3800 provide be a good alternative at a low price?
Cheers
Cheers
Not really in the same league. Go with the C2D.
Hades said:
Some of the motherboards are OEM. What does this mean? What is missing? Thanks.
The board will arrive in a plain box, I think no manual or leads and you may get a back plate.
Rob
Rob
Thanks. The one I have my eye on is almost half the normal price. But it normally includes a break-out box for HDTV and component video out, etc. The description says it's included but I suspect that is just a quick cut-and-paste job. So I was wondering what the chances of it having that adapter were?
Thats a tuff one 50:50 chance, I have not bought anything from the clearance section, give them a call in the morning.
Rob
I asked OcUK about the OEM motherboard and had this response:
Thank you for your webnote, i bellive that this comes just as the bog standard board nothing else thank you.
So be careful if buying and ignore the description which is obviously just cut and paste and not accurate if it mentions additional items.
