OCUK competition card arrived! few questions!
20 Jul 2007
A sunnier or damper area than Ron-ski....
Hi folks,
The GFX 285 I won in the ocuk competition has just arrived and I'm fighting with the non-existent instructions to get it up and running.
It has two 6 pin pci-ex power cords which I've plugged in and it boots up to the windows start screen and then freezes... there's also a very small two pin cable (like one of those fan cables) - can anyone tell me what this does and if I need to plug it in (if so where!)
Might try reseating the card in the meantime...
Hi folks,
Sorry I can't be of much help, but I think the little 2 pin cable is a audio passthrough from your sound card to your graphics card to allow audio through HDMI.
Don't reseat the card, until you know that the card is alive and not DOA. If it was dead and you RMA it having removed the HS, then they will refuse the RMA.
I think that it only needs two six pin cables (I don't have one, so I'm not sure about that) Is your PSU up to the job.
Oh and congratulations, I like your design very much :)
Have you removed all previous graphics drivers? Freezing at Windows loading sounds like a driver conflict to me.
Boot up in safemode, remove all graphics drivers, reboot, install newest nVidia drivers :)
lol @ this, how is reseating removing the heatsink?
Hi Ben - by reseat I mean, take it out the PCI slot and refit it, not start the assault on the heatsink etc! ;)
Hmmm, was hoping the PSU would be up to it, but could possibly be the issue - have a Corsair 620W - box says 550W recommended by Nvidia, XFX 'ideal' is 630W - that said I'm not exactly heavily loaded with drives etc - have them external to the system:
Q6600 - standard clocking
8gb ram
5 or 6 fans
GTX 285
2 HDs and a DVD Rewriter
Onboard sound etc
This sound doable? (googled around and folk seem to be running it on even lower PSUs without too much issue - seems to be more about the 40A being available)
The Corsair HX620 is plentiful.. I really doubt the PSU is the issue :)
UV - think you might be right, no I haven't (was too excited - besides the instructions say to do it after windows boots up)
AAHH! we have life as we speak, it apparently needed 15mins to boot up!?!? Now let's see if I can break the back of this card! ;)
Thanks ever so much for all your tips! Will keep you posted on whether it works!
For me "reseating" is taking off the HS, cleaning it, new thermal paste, reseating the heatsink. Apparently to you and the OP it means unplugging the card =\
You described reseating the cpu. Reseating a PCI card is just taking it out and putting it back in again imo.
Hmm, just trying to work out how to uninstall the bleedin ATI drivers - there doesn't seem to be an uninstall option in Vista uninstall programs, device manager it's already disappeared, maybe Vista's trying to be clever...
Reseating is removing the graphics card and reinserting it. To everyone.
The little cable is an SPDIF cable which you will need to connect from your card to mobo if you want to hear sound via HDMI.
Ah, silly me - to uninstall radeon drivers, uninstall is greyed out and you need to click to 'update' and then uninstall is hidden within update! It's like they don't want to lose a customer to nvidia or something... ;)
Ah, gotcha, so guess that's if I wanted to hook the PC up to a plasma or something, then the sound would also be able to go through the HDMI cable? Does it just plug into the audio connectors on the MB then?
Nah it's 2x 6 pin - I 'thought' the 280 was 6 and 8 and they dropped it for the 285s, but I know very little indeed, so could be wrong!
The long bootup is probably a driver issue. I'd start in safe mode and uninstall the ATI drivers, then reboot, then use driversweeper to remove all traces left. Then you can install the latest geforce drivers for the card and you should be on your way.
Could be so, I've not played around with the 285 much compared to the 260 and 280, the only 285 I've got my hands on used 6+8.
