OcUK COMPLETE CPU & GPU WATERCOOLING BUNDLE
11 Dec 2005
Cheshire
OcUK Complete CPU & GPU Watercooling Bundle @ £233.98 inc VAT
The OcUK Complete CPU & GPU Watercooling Bundle is watercooling made easy, designed for the budding computer enthusiast who wants to maximise the performance of their system. All components are tested for compatibility so you don't have to worry about tubing sizes, pump flow rates and fluid choices. Here at OcUK we have done the hard work for you. Complete with a CPU block,GPU Block (optional), tubing, fittings, pump, reservoir, radiator and fluid all you have to do is select what colour fluid you desire.
- x1 EK Supreme i7 High FlowClear Top (775/1156/1366/AM3) CPU Water Block
- x1 XSPC DDC 18w Pro Pump/Reservoir
- x4 Masterkleer 7/16" Tubing - 1m (Total 4 meters)
- x8 1/2" Fitting G1/4" with O-Ring High Flow Stubby Connector - Black Nickel
- x8 XSPC Tubing Clip For 1/2" and 7/16" Hose
- x1 Fluid XP Extreme (Choice of colours)
- x1 Swiftech RX360 Triple Radiator
- x3 Sharkoon Silent Eagle 120mm 1000RPM fans(w/ screws)
- x1 Optional GPU full cover block of your choice for either ATI or Nvidia graphics solution
Includes free 6-page colour installation manual
Note - Please ensure the system case has the appropriate spacing and capacity to fit a full watercooling loop.
Only £233.98 inc VAT.
ORDER NOW
I think these kits are amazing for 1st time w/c ers! My 1st time I was stressed and worried about, tubing, barbs, leaking, corrosion etc. Ended up buying a swiftech h20-220 and after that learned a lot about watercooling and feel more confident that you have enough knowledge to go an customise your own :) great work!
you could get a second GPU in there depending on thermal output.
for instance
a 4ghz i7 would be alright on a double radiator
a 4ghz i7 and a 5870 would be alright on a good triple radiator like the one in this kit
if you wanted to run another 5870 in crossfire, i think it would be ok on a triple but you may need to run the cpu a little lower or refine your voltage
any chance of getting the option to change the radiator for a quad?, similar to the option you have in the cheaper watercooled bundle.
You can give sales a call and I'm sure they can sort you out with a quad rad. The price difference between the two isn't very much. I can give you my email if you need me to spec you up a loop?
Radiator Description wrong
Hi,
i've been looking at this, and it seems the best kit compared to other sites.
the radiator says Swiftech RX360 Triple Radiator, but on the swiftech website there isn't one of this model number, but there is a XSPC RX360.
can someone confirm what radiator comes with it?
also how do i get an ickle discount if i order today :D
Thanks
Rich
it is the XSPC radiator, i will get nath to sort this out now
all products are pre-discounted for your convenience ;)
add the components together in a basket and compare the total to the deal with this kit
Thanks, you're right and its still £10 - £35 then other's i've researched!
v.tempted & nearly ready to buy - but, I will need a new case to take the triple rad. I'm planning an i7 setup with a single 5970 and will be searching though the specs, but if the knowledge is out there, can anyone tell me which cases will accommodate the triple Rad and a 5970 ........
Thanks.
Quick question!
Can this be fitted on an Antec 1200?
There isn't really anywhere to put a radiator. A double wont fit on the 2 fans at the back because they are too close to the top of the case :(
Well there's nowhere inside the case without some modding. It has those holes in the back specifically for water cooling tubes though, so I guess you could attach the radiator on the outside.
Thanks.
Hi. I bought this setup on wednesday. Installed it thurs night. I've got a i7 920, gtx470 it all fits perfectly in a coolermaster haf 932. If you want I can upload a couple of pics and measure the gap for the a 5970?
......... That would be very helpful. Thanks!
Pic
Hi,
Picture supplied (re-installation incomplete);
According to guru3d, the 470 is 24.5CM and the 5970 is 30CM, i've got another 8CM spare so yours would fit with 2.5CM to spare.
took about 3 hrs to setup (had to rearrange my case), the GFX card was the most time consuming!
CPU on Akasa 967 @ 3.7GHz = 95° throttling :(
CPU on water @ 4GHz = 60° :)
GPU on stock = 90°
GPU @ 830MHz = 45°
so all in all, a lot better!
Hope this helps!
