- 11 Dec 2005
- Cheshire
OcUK Complete Watercooling Bundle @ £189.99 inc VAT
The OcUK Complete Watercooling Bundle is watercooling made easy, designed for the budding computer enthusiast who wants to maximise the performance of their system. All components are tested for compatibility so you don't have to worry about tubing sizes, pump flow rates and fluid choices. Here at OcUK we have done the hard work for you. Complete with a CPU block, tubing, fittings, pump, reservoir, radiator and fluid all you have to do is select what colour fluid and radiator size you desire.
- x1 EK Supreme i7 High FlowClear Top (775/1156/1366/AM3) CPU Water Block
- x1 XSPC DDC 10w Pro Pump/Reservoir
- x2 Masterkleer 7/16" Tubing - 1m (Total 2 meters)
- x6 1/2" Fitting G1/4" with O-Ring High Flow Stubby Connector - Black Nickel
- x6 XSPC Tubing Clip For 1/2" and 7/16" Hose
- x1 Fluid XP Extreme (Choice of colours)
- x1 Single/Triple/Quad Radiator (Choice of sizes)
Note - Please ensure the system case has the appropriate spacing and capacity to fit a full watercooling loop. Fans are required for active cooling on the radiator.
Only £189.99 inc VAT.
ORDER NOW
ORDER NOW
