OcUK Edge Full Tower Case - arriving tomorrow.
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
An excellent solution for any high end rig which requires space, excellent cooling, noise reduction and and more space. Space is a must with this case. It is very spacious. Lots of space with this chassis. :) lol
OcUK EDGE Full Tower PC Case - Black @ £134.99 inc VAT
The Nexus Edge case is a full-tower chassis that is compatible with ATX/Flex, ATX/Micro ATX and Full ATX motherboards. Even extended ATX motherboard will fit inside of the chassis without any issues!
Noise absorption wave foam
The side panels of the Edge case are fully covered with noise absorption wave foam to absorb noise and sounds coming from the components installed inside the case.
The front panel is manufactured from 3mm thick aluminium with three stunning finishes. The right hand side of the front panel has a recognisable aluminium hairline finish, while the left hand size has a sand-sprayed mat finish. Where these two different finishes meet, a thin aluminium strip has been polished to a mirrored, given it a elegant look.
Good cooling inside any case is an absolute must, which is why the Edge is supplied with three "Real Silent" 14cm case fans. These fans run at 1000 RPM and move a massive amount of air whilst remaining ultra quiet (18 db(A)).
When installing the power supply of your choice you will notice that the PSU sits on soft rubber pads. These pads prevent resonance and vibration. There is also plenty of space around the PSU to allow it to "breathe" so the fan speed of the PSU is not influenced by air obstruction.
At the air intake areas, such as at the front 14cm case fan, air filters have been positioned to keep the dust out of the case. There are also two filters installed at the bottom of the case to further reduce dust build up.
Finally, to keep things nice and simple the HDDs and optical drives can be fitted without any tools.
- Massive computer enclosure
- Acoustic material to help reduce noise
- 10x 3.5" and 8x 5.25" drive bays
- Lockable doors
- Plush aluminium front door
- Supplied with three 140mm fans, only 18.0 dB(A)
- Motherboard size ATX, Full ATX, Micro ATX, Full ATX, Extended ATX
- Padding Noise absorption wave foam
- Case fans: 3 x 140mm | 1000RPM
- Front ports: E-SATA, 2x USB 2.0, MIC and AUDIO
- 5.25" bay exposed: 8 tool less
- 3.5" bay exposed: 1 tool less
- 3.5"bay hidden: 9 tool less
- Expansion slots: 7 tool less
- Dimensions(mm): 642 x 239 x 576 (L x W xD)
- Front cover: Aluminium + ABS
- Chassis material: SECC 1.0 t
- Watercooling: 4 pipe holes for liquid cooling
- Feet: Rubber adjustable feet
Only £134.99 inc VAT.
ORDER NOW
sounds very good, but there are a few things holding me back
1) an all black interior would have looked better in my opinions
2) the ODD/HDD rack
but overall nice finish and nice price :)
The outter panels are amazing quality, and looks good, the only downfall as stated already is the interior should have been black.
Where is the front fan position as looking at the internal pic it looks like its at the bottom if it is then the airflow is going to be horrible in that case.
