*****OCUK EIGHTH ROUND OF DEALS - POWER SUPPLIES*****
17 Oct 2002
Stoke
We've offered you most of the components to build a PC but you need to power it so here's some PSUs for you all:
OcUK Swift 450W Silent Power Supply @ £15.26 inc VAT
The OcUK swift power supply is sourced and built from high quality components making these reliable power supplies for anyone who is building a home or office computer. They feature a 120mm fan for low noise operation keep the whole PC quiet. These units offer incredible value for money and are ideal for any PC used in the home or office.
- AC input Voltage: 95-132VAC or 190-264 VAC switchable
- AC input Frequency:50HZ/60HZ
- AC input Current:10A res max. for 115VAC, 5A res max. for 230VAC
- Ripple-noise:5A res max. for 230VAC
- Operation temperature:0oC ~+40oC
- Hold up time :16ms
- Dielectric withstand:Input to frame ground 1800VAC for 1 second
- Power good signal:Power on delay time 100ms to 500ms
- Ppower fail :oC>=1ms
- Overload protection :150%
- Universal 20+4 Pin Main ATX Power Connector X 1
- 4 Pin + 12V Power Connector X 1
- Peripheral Connector (4Pin for HDD, CD ROM…etc) X 4
- Floppy Connector (4 Pin) X 1
- Latest L-Type Serial ATA Power Connector X 1
Only £15.26 inc VAT.
ORDER NOW
OcUK Swift 550W Silent Power Supply @ £18.79 inc VAT
The OcUK Swift power supply is sourced and built from high quality components making these reliable power supplies for anyone who is building a home or office computer. They feature a 120mm fan for low noise operation keep the whole PC quiet. These units offer incredible value for money and are ideal for any PC used in the home or office.
- Power fail :oC>=1ms
Only £18.79 inc VAT.
ORDER NOW
OcUK Swift 650W Silent Power Supply @ £22.31 inc VAT
The OCuK power supply is sourced and built from high quality components making these reliable power supplies for anyone who is building a home or office computer. They feature a 120mm fan for low noise operation keep the whole PC quiet. These units offer incredible value for money and are ideal for any PC used in the home or office.
Only £22.31 inc VAT.
ORDER NOW
OCUK Swift 750W Silent Power Supply @ £28.19 inc VAT
- 120 mm slience bearing fan
- Voltage: 95-132VAC or 190-264 VAC switchable
Only £28.19 inc VAT.
ORDER NOW
Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK) @ £86.99 inc VAT
Enthusiasts looking for the optimal in price performance PSU technology will find the Corsair TX650W/TX750W series of PSUs will meet even the most demanding of required specifications. The Corsair TX650W/TX750W power supplies are engineered using advanced technology and components typically found with high performance power supplies. With design features such as a dedicated, single +12V rail offer the maximum compatibility with the latest system components. Energy efficient circuitry capable of delivering greater than 80% efficiency ratings across 20%, 50%, and 100% load conditions make the TX family of PSUs ideal for the value/quality conscious enthusiast. With a large 120mm diameter temperature-controlled fan that is ultra quiet, yet still more than sufficient to cool the internals of the system, reliability and stability are no longer worries for the gamer, overclocker or enthusiast and high-end system builder.
- Supports ATX12V v2.2 standard and older ATX12V 2.01 spec
- Ultra-quiet 120mm double ball-bearing fan delivers excellent airflow
- 80%+ energy efficiency at 20%, 50% and 100% load condition for less heat generation and lower energy bill
- 99% Active Power Factor Correction provides clean and reliable power to your system
- Universal AC input 90~264V automatically scans and detects the correct voltage
- Dedicated single +12V rail offers maximum compatibility with latest components
- Over Current/Voltage/Power Protection, Under Voltage Protection, and Short Circuit - Protection provide maximum safety to your critical system components.
- High quality Japanese capacitors provide uncompromised performance and reliability.
- Extra long cables support full tower size chassis.
- TX650W Dimension: 5.9"(W) x 3.4"(H) X 5.5"(L);
- MTBF: 100,000 Hours
Only £86.99 inc VAT.
ORDER NOW
OCZ StealthXStream 700w Silent Power Supply @ £63.99 inc VAT
Designed for the value-minded gamer seeking simple, quiet performance, the StealthXStream includes OCZ’s acclaimed reliability and feature-sets with a lower price point. Ideal for system builders and enthusiasts who prefer a low-key PSU, the StealthXStream focuses on performance, quality, and quiet operation. Even at peak loads, the 700W StealthXStream remains virtually silent and excludes flashy LEDs ensuring the power supply is not seen or heard. The StealthXStream is kept supremely cool with a large 120mm fan features a standard ATX power supply form factor resulting in a compact footprint to accommodate virtually all computer towers. With a sustained output of 700W and four +12V rails to provide uniform distribution of power, the StealthXStream is well-suited for and driving today's higher end systems. The rock solid StealthXStream is built to provide sufficient output to power dual GPU and CPU platforms, complete with two PCI-Express cables and a 4/8 CPU auxiliary connector which are wrapped in a flexible mesh promoting a tidy environment inside the case. The OCZ StealthXStream provides Universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, yet stable supply of power. All OCZ StealthXStream power supplies come backed with an industry-leading three year OCZ PowerSwap Warranty for the ultimate peace of mind.
- 700W Configuration
- OCZ PowerWhisper™ Technology
- Internal 120mm fan
- 3 year warranty backed by OCZ’s exclusive PowerSwap™ replacement program. No more endless return-for-repair loops!
- 150 x 140 x 86mm
- ATX12V v2.2 and EPS12V
- OCZ ConnectAll™ universal connectors:
- 1 x 20+4Pin ATX
- 1 x 4-pin/8-pin CPU (supports double CPUs/supplies stable voltage)
- 2 x PCI-E (1 6-pin & 1 8-pin)
- 6 x 4-pin peripheral
- 1 x 4-pin floppy
- 3 x S-ATA
- High efficiency 80% @ 115V (Typical load) 83% @ 230V (Typical load)
- Overvoltage/Overcurrent/Short-Circuit protection
- Active PFC
- MTBF:100,000 hours
- 100~240Vac 10-5A 50/60Hz
- +3.3V(36A), +5V(30A), +12V1(18A), +12V2(18A), +12V3(18A), +12V4(18A)
Only £63.99 inc VAT.
ORDER NOW
