**OcUK EXCLUSIVE: AVEXIR MPOWER MEMORY!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK is the exclusive European/UK reseller/distributor for all Avexir memory and as such we bring you the new amazing Mpower range of memory:-
Avexir MPower Series 32GB (4x8GB) DDR3 PC3-12800C10 1600MHz Quad Channel Kit (AVD3U16001008G-4CM) @ £129.95 inc VAT
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Mpower series is designed to be a perfect visual match for MSI Mpower mainboards and certain models of Asrock mainboards, giving you a look which shall make you the envy of all your friends.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
Features:
- Black PCB
- Black/Yellow high performance heatspreaders
- Blue LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 10-10-10-27
- Quad Channel Kit: (4x8GB)
- 100% tested at 1600MHz in Intel & AMD based motherboards
- Lifetime Warranty
- Sandybridge compatible
- Bulldozer compatible
Only £129.95 inc VAT.
ORDER NOW
Avexir MPower Series 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel Kit (AVD3U16000904G-4CM) @ £71.99 inc VAT
Features:
- Black PCB
- CAS Timings: 9-9-9-24
- Quad Channel Kit: (4x4GB)
- Lifetime Warranty
Only £71.99 inc VAT.
ORDER NOW
Avexir MPower Series 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (AVD3U16001008G-2CM) @ £65.99 inc VAT
Features:
- Black PCB
- Dual Channel Kit: (2x8GB)
- Lifetime Warranty
Only £65.99 inc VAT.
ORDER NOW
Avexir MPower Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (AVD3U16000904G-2CM) @ £35.99 inc VAT
Features:
- Black PCB
- Dual Channel Kit: (2x4GB)
- Lifetime Warranty
Only £35.99 inc VAT.
ORDER NOW
Of course this memory goes great with the following MSI products:- :D :D :D
MSI HD 7970 Lightning 3072MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** with FREE Sleeping Dogs PC Game @ £399.95 inc VAT
Key Features:-
- Unlocked BIOS: One click to unlock all protections for extreme overclocking
- Digital PWM Controller: More stable and precise voltage by digital signal
- Enhanced Power Design: 2X Power output for maximum OC potential
- An add-on device on the back of R7970 Lightning (Behind GPU) for the overclocking stability
- Provide 88% higher power capacity and eliminate power noise (ripple)
- Dust Removal technology on Twin Frozr IV keeps dust out for the best thermal condition
- Dual Form-in-one Heatsinks provide better heat dissipation and strengthen the structure
- Meet MIL-STD-810G standard to ensure the best stability and quality.
- Adopt CopperMOS, Hi-c CAP, Golden SSC, and Dark Solid CAP
- Core Clock Speed: 1070MHz
- Memory Clock Speed: 5600MHz
- Warranty: 3 Year
Only £399.95 inc VAT.
ORDER NOW
MSI GeForce GTX 680 Lightning 2048MB GDDR5 PCI-Express Graphics Card @ £439.99 inc VAT
Specifications:-
- Dual BIOS (BIOS 1: 1110/1176) & (BIOS 2: UNLOCKED, Upto 1.21v GPU voltage)
- Core Clock: 1110 (GK104)
- Core Boost Clock: 1176MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2220MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 2x 8-Pin PCI-E Connectors required
- Warranty: 3 Years
Only £439.99 inc VAT.
ORDER NOW
MSI Z77 MPower Intel Z77 (Socket 1155) DDR3 ATX Motherboard @ £139.99 inc VAT
Specifications
- Supports 3rd Gen Intel Core i7 / Core i5 / Core i3 / Pentium / Celeron for LGA1155 Socket
- Intel Z77 Chipset
- 4 DIMM support for DDR3 1066 / 1333 / 1600 / 1866 / 2133 / 2400 / 2677 / 2800 / 3000 up to 32GB Max
- Intel HD Graphics 2500/4000 with integrated HDMI / DVI / DSUB ports
- ATI CrossfireX, Nvidia SLI & Lucid Virtu Universal MVP Support
- 8 Channel (7.1) HD Audio with THX TruStudio Pro
- 4x SATA 3Gb/s (Intel) With RAID Support
- 2x SATA 6Gb/s (Intel) With RAID Support
- 8x USB 3.0 (6 external / 2 Internal)
- 8x USB 2.0 (2 external / 6 Internal)
- 3x PCI-E 3.0 x16 slots
- 4x PCI-E x1 slots
- Gigabit LAN
- Built In Wi-Fi 802.11 b/g/n
- Built In Bluetooth 3.0+HS
- 3 Year Warranty
Only £139.99 inc VAT.
ORDER NOW
Totally awesome looking kit guys and the quality, well sublime. :)
