~~~~~OcUK Exclusive - Corsair Vengeance 4GB Sandybridge Kits!~~~~~
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Right as there was a serious lacking on 4GB Vengeance kits OcUK has used it brains and has dismantled 6GB kits and re-tested them in dual channel with Sandybridge at 1.50v.
Resulting OcUK is the only etailor to offer a Vengeance 4GB Dual Channel Kit which operates at 1600MHz with 8-8-8-24 timings, grab one:-
Corsair Vengeance 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (CMZ4GX3M3A1600C8) ***OcUK Exclusive*** @ £64.99 inc VAT
CORSAIR high performance Vengeance memory module 4GB (2x2GB) 1600MHz 8-8-8-24, CL8, 1.5V for motherboards using Intel dual channel processors. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel P67 DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- 4096 Megabytes of DDR3 memory
- Two matched 2GB modules
- 100% tested at 1600MHz in P67-based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Perfect for Sandybridge
- *Note these were tri-channel kits which have been broken up and re-tested as dual-channel kits for P67 sandybridge and operate 1.45v-1.55v for Sandybridge setups.
Was [£79.99] Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
Corsair Vengeance Memory Range - 1.50v Sandybridge compatible
