Hi there
The last Corsair Vengeance green memory kit we had was very popular, we now have a 2133MHz version, check it out:-
Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-17200C11 2133MHz Dual Channel Memory Kit - GREEN (CML8GX3M2A2133C11G) @ £67.99 inc VAT
Vengeance LP Performance Memory modules, 8GB (2x4GB) DDR3 2133MHz CL11 Unbuffered DIMM Memory with XMP 1.3 for AMD, Intel Processor platforms, including 2nd – 4th generation Intel Core i7 and i5 systems. Every Vengeance memory module provides users with outstanding performance and high quality. Vengeance memory modules are built using carefully selected DRAM to allow excellent overclocking performance and rock solid stability.
Features:-
- 8GB total capacity provides ample headroom for the most demanding user
- 11-11-11-27 latency
- Intel XMP (Extreme Memory Profile) support
- Compatible with Intel X79, Z68, Z77, Z87, Z97, AMD and P67 platforms
- Speed: 2133MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
- Pin Voltage: 1.50-1.60V
- Limited Lifetime Warranty
Only £67.99 inc VAT.
ORDER NOW
Features:-
- Speed: 2133MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
ORDER NOW
