*****OcUK Exclusive - OCZ Blade Memory Returns with new Flagship 6GB Kit!!!*****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Well it makes me very proud to say OCZ have given OcUK rights to a one month exclusivity period on the new OCZ Blade ST 6GB Kit. That means from the day we take delivery you will only be able to buy this kit from us, our competitors won't get it for a month later.
As always OcUK bringing you the latest and best cutting edge technology first, now lets check out this bad boy:-
OCZ Blade ST 6GB (3X2GB) 2000MHz PC3-16000C8 Triple Channel Kit ***OcUK Exclusive*** [OCZ3BST2000C8LV6GK]
OCZ low-voltage Blade ST DDR3 kits are designed specifically for the Intel® Core™ i7 processors. Configured for triple channel mode, these ultra-compatible 6GB kits ensure optimal performance with an ideal combination of low power requirements at 2000MHz or alternatively run at 1600MHz at lower voltage. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the X58 Chipset and choice CPU to deliver the maximum stability for performance desktops.
The Blade ST heatspreader aims to enhance heat dissipation to improve the longevity and stability of high frequency memory modules with new propriety design that has numerous slotted “channels” to efficiently offload heat away from memory chips and PCB. These new anodized aluminum heatspreaders are mechanically bound on each side for ultimate integrity, with a thin low-profile form factor that allows modules to be installed side by side to make use of all DIMM slots.
OCZ Blade ST Low Voltage Triple Channel Kits are 100% hand-tested for quality assurance and each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
Features:-
- 2000MHz DDR3
- CL 8-9-8-24 (CAS-TRCD-TRP-TRAS)
- Blade ST Heatspreader
- Lifetime Warranty
- 1.45-1.65 Volts
- 240 Pin DIMM
Price: £157.44 +VAT (£184.99 Inc. VAT)
Pre-Order NOW!
As this is an extremely fast kit with aggressive timings yields are expected to be low, in the whole month exclusivity period OCZ estimate they will only be able to manufacturer 200pc of these for us, so make sure your one of the first to pre-order.
I swear by OCZ as they have never let me down.
My friend recently bought the OCZ Reaper 6GB 2000MHz version but now he wished he waited as its a great product for the price. Lower timings and better design, and no silly tall HS.
Don't fret about the green pcb, its not a big deal as most PC3-16000 by OCZ are the same, bar the competitors who used black. I know it would probably void the warranty, but would it be safe to carefully spray just the green pcb black?
yep - its probably a cost issue. a lot of people dont worry about aesthetics though and the 2000mhz tag is much more important
its a good price for the spec
for instance - the first edition OCZ blade C7 2000mhz kits were £500
the reason for this is because they were hand picked and tested. since memory manufacurers stopped using Elpida ICs the chances of getting low cas/high frequency for a fair price is slim.
thats what makes these good value
Doe's the colour matter really? Unless you have a window on the side and even then you would be looked straight down on them you would see little of the PCB.
I need to hurry up and decide the spec of my PC might get these if I go I7
surly cooler don't matter, consdering that some people may well have memory coolers anyway assuming these blades would fit under them
