Hi Guys
Recently I have revamped our Fittings Section on the website to make each category easy to navigate and find what you need.
Fittings for 1/2" ID [19/13mm] Tubing
Fittings for 3/8" ID [13/10mm] Tubing
Fittings for 7/16" ID [16/11mm] Tubing
Fittings for 5/8" ID [16/10mm] Tubing
I have trawled our suppliers stock lists to find the best fittings for our OcUK Value range. Rest assured that every fitting in the range has been picked to offer brilliant performance and value whilst looking near identical to fittings from the more popular and expensive brands.
Essentially this range offers you the look for less than half of the price.
We have a range of bulkhead fittings and fillports on the way soon too!
All of these fittings work brilliantly with the EK PSC and other Rotary fittings.
Here are some of the highlights of the new range:
OcUK 1/2" G1/4 - High Flow Style - Shiny Silver - Compression Fitting @ £3.49 inc VAT
The answer to all barbed fittings! Finally no barbed fittings are required for a Highflow system and the highest possible safety can be ensure with this compression fitting. the special short thread also allows application of this fitting on waterblocks which usually require a spacer ring for fitting installation. The hose end is simply pushed onto the fitting and fixated and securely sealed by the union nut, resulting in an absolutely tight seal. The integrated O-ring additionally ensures a tight seal with the waterblock. No tools are needed for installation, just tighten by hand and you are all set to go - That's how easy fitting installation can be!
Technical details:
Thread size: G1/4"
Thread length: 5mm
Height: 21mm
Diameter: 26mm
Extent of delivery:
1x 19/13mm compression fitting G1/4" - compact - silver nickel plated
Please note: The fitting is compatible with 19/13mm hoses.
Only £3.49 inc VAT.
ORDER NOW
OcUK 1/2" G1/4 - High Flow Style - Black Nickel - Compression Fitting @ £3.49 inc VAT
Technical details:
Thread size: G1/4"
Thread length: 5mm
Height: 21mm
Diameter: 26mm
Extent of delivery:
1x 19/13mm compression fitting G1/4" - compact - black nickel plated
Only £3.49 inc VAT.
ORDER NOW
OcUK 3/8" G1/4 - FatBoy Style - Shiny Silver - Barb Fitting @ £1.58 inc VAT
Robust high-quality nickel plated barbed fitting with cylindrical thread (G1/4"). The fitting is suitable for PVC, PU, PA, silicone and PE hoses with an inner diameter of 10mm. With integrated 1/4" Perbunan(r) O-Ring seal.
We recommend the use of hose clamps or zip ties for best possible safety!
Note for watercooling beginners:
The connectors for hoses(7/16", 3/8",1/2") are provided with measurements in mm in our shop. These can differ by +-1mm, which is no problem as hose clamps have to be used for installation. If the hose is to be mounted without a clamp, a larger fitting should be chosen. With some fittings that tend to be larger, it is possible though that a hose with an inner diameter of 13mm actually does seal without a hose clamp.
Overview:
10mm (3/8") hose clamp: up to 8mm none, from 10mm up required
10mm (7/16") hose clamp: up to 8mm none, from 10mm up required
12mm (1/2") hose clamp: up to 11mm none, from 12mm up required
13mm (1/2") hose clamp: up to 11mm none, from 13mm up required
Only £1.58 inc VAT.
ORDER NOW
OcUK 3/8" G1/4 - FatBoy Style - Black Nickel - Barb Fitting @ £1.58 inc VAT
Robust high-quality black nickel plated barbed fitting with cylindrical thread (G1/4"). The fitting is suitable for PVC, PU, PA, silicone and PE hoses with an inner diameter of 10mm. With integrated 1/4" Perbunan(r) O-Ring seal.
Overview:
Only £1.58 inc VAT.
ORDER NOW
OcUK 3/8" G1/4 - High Flow Style - Shiny Silver- Compression Fitting @ £2.48 inc VAT
High quality screw-on fitting with cylindrical thread (1/4"). The hose is fixated and sealed tightly by the union nut, yet it can easily be removed with one hand. This system ensures maximum safety and ease of installation. With integrated 1/4" Perbunan(r) O-Ring seal.
Technical data:
Material: black Nickel coated brass
Length: Approx. 28mm incl. thread
Wrench size: 20mm
Compatibility:
The 13/10 fittings are compatible to 13/10mm and 12,7/9,5mm (3/8") hoses
Extent of delivery:
1x 13/10mm (10x1,5mm) screw-on fitting G1/4" - knurled
Only £2.48 inc VAT.
ORDER NOW
OcUK 3/8" G1/4 - High Flow Style - Black Nickel - Compression Fitting @ £2.48 inc VAT
Technical data:
Wrench size: 20mm
Compatibility:
Extent of delivery:
Only £2.48 inc VAT.
ORDER NOW
OcUK 7/16" G1/4 - High Flow Style - Shiny Silver - Compression Fitting @ £3.29 inc VAT
The answer to all barb fittings. Finally the build of a Highflow-system is not obstructed by the use of barb fittings anymore. From the beginning on trust can be put in the maximum safety provided by this fitting. The short thread also allows for use with waterblocks that usually require the use of a spacer. As soon as the union nut is tightened the hose is sealed tightly. The O-ring, which sits on the waterblock when screwed in, gives additional safety. No tools are needed for installation:Just tighten by hand. That is easy installation!
Technical data:
Thread: 1/4"
Height: 27mm
Thread length: 5mm
Height(wihtout thread): 22mm
Diameter: 22mm
Extent of delivery: 1x straight screw-on fitting G1/4"
Please note:
All 16/10mm fittings are compatible with 15,9/11,1mm & 15,9/9,5mm hoses
All 16/13mm fittings are compatible with 15,9/12,7mm hoses
Only £3.29 inc VAT.
ORDER NOW
OcUK 7/16" G1/4 - High Flow Style - Black Nickel - Compression Fitting @ £3.29 inc VAT
Technical data:
Length: Approx. 27mm
Thread length: approx. 4mm
Compatibility:
16/13mm hoses
Extent of delivery:
1x 16/13mm (10x1,5mm) screw-on fitting G1/4" - knurled - black nickel
Only £3.29 inc VAT.
ORDER NOW
OcUK 5/8" G1/4 - High Flow Style - Shiny Silver - Compression Fitting @ £3.38 inc VAT
Technical data:
Thread: 1/4"
Height: 27mm
Thread length: 5mm
Diameter: 22mm
Please note:
Only £3.38 inc VAT.
ORDER NOW
OcUK 5/8" G1/4 - High Flow Style - Black Nickel - Compression Fitting @ £3.38 inc VAT
Technical data:
Compatibility:
16/13mm hoses
Extent of delivery:
Please note:
Only £3.38 inc VAT.
ORDER NOW
OcUK G1/4 - Screw in Seal Cap - Knurled - Shiny Silver @ £0.98 inc VAT
Knurled screw-in plug to allow a safe seal of filling opernings or other threads. Seals safely with the integrated O-ring seal. The pictures diplay the top and bottom of the screw-in plug.
Material: Silver nickel coated brass
Thread size: G1/4"
Extent of delivery:
1x Seal plug
Only £0.98 inc VAT.
ORDER NOW
Technical details:
Thread size: G1/4"
Thread length: 5mm
Height: 21mm
Diameter: 26mm
Extent of delivery:
Only £3.49 inc VAT.
ORDER NOW
Technical details:
Thread size: G1/4"
Thread length: 5mm
Height: 21mm
Diameter: 26mm
Extent of delivery:
Only £3.49 inc VAT.
ORDER NOW
Overview:
Only £1.58 inc VAT.
ORDER NOW
Overview:
Only £1.58 inc VAT.
ORDER NOW
Technical data:
Wrench size: 20mm
Compatibility:
Extent of delivery:
Only £2.48 inc VAT.
ORDER NOW
Technical data:
Wrench size: 20mm
Compatibility:
Extent of delivery:
Only £2.48 inc VAT.
ORDER NOW
Technical data:
Thread: 1/4"
Height: 27mm
Thread length: 5mm
Diameter: 22mm
Please note:
Only £3.29 inc VAT.
ORDER NOW
Technical data:
Compatibility:
16/13mm hoses
Extent of delivery:
Only £3.29 inc VAT.
ORDER NOW
Technical data:
Thread: 1/4"
Height: 27mm
Thread length: 5mm
Diameter: 22mm
Please note:
Only £3.38 inc VAT.
ORDER NOW
Technical data:
Compatibility:
16/13mm hoses
Extent of delivery:
Please note:
Only £3.38 inc VAT.
ORDER NOW
Thread size: G1/4"
Extent of delivery:
1x Seal plug
Only £0.98 inc VAT.
ORDER NOW
