OcUK eyefinity bundles
With there being no DP connections on these monitors, what's the best way to connect them all and have eyefinity work? Would 2xDVI and 1xHDMI work?
Looking into trying these.
I'm not sure tbh, I've been led to believe on my 7 series nv card I can use any connection but that wasn't the case when I have my 5 series ATI where one had to be DP or use an active adaptor!
You would need an Active Display Port Adapter like Accell UltraAV DisplayPort 1.1 to HDMI 1.4. 1 of the 3 monitor connections must be done using a Display port with Active Adapter to DVI/HDMI, needed for both kits and hopefully included in the bundle. You'd be advised to contact them to ensure you get the correct adapter for your graphics card. Only applicable to AMD cards, Nvidia set-up is different.
If your monitors have Display Port on them then adapters are not required as far as i know.
Seriously looking at picking up this bundle. I know yours hasn't arrived but do you know if the individual monitor stands are included along with the free triple monitor stand ?
Just wondering if you 'have' to use the triple stand or could you use each monitor seperatly.
Here's my new 3 screen setup for those looking for multi-screen porn in mean time :D
Need some photos with lights on too.
Still got some playing to do to decide if keeping. Didn't get much time to play things yesterday. But it looks so much neater than my dual screen setup.
DSC07653 by chris_rabe, on Flickr
Looking good mate. I've just bought 3 AOC 23" IPS panels, to give it a go. What do you think of the Overclockers monitor stand that came with the bundle ? I'm waiting on DPD as we speak for mine now. There isn't much info on there website about it.
