** OcUK FANS!!! **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
It gives me great pleasure to announce the arrival of the brand new OcUK Tech Labs fan.
Working in conjunction with our friends at Zaward, we have chosen their Golf 3 fan to be the basis for the OcUK Tech Labs fan.
Delivered in superb Tech Labs branded packaging with matching high quality decals on the fan hub, the OcUK ZG3-120TL is perfect as a case fan, CPU Cooler fan or a watercooling radiator fan.
This fan has been specified to be used in conjunction with a fan controller for maximum user control and performance.
OcUK Tech Labs - Zaward Golf III Fan 120mm ZG3-120TL Black/White @ £8.99 inc VAT
The OcUK ZG3-120TL has been developed in conjunction with Zaward, a world leader in computer cooling. The ZG3-120TL is a high performance fan designed for ultimate cooling potential.
The distinctive shape of the Zaward GOLF FAN has become a trademark of ZAWARD and our OcUK Tech Labs branded fan is a no compromise solution for the enthusiast seeking ultimate performance.
The G3 Golf III Fan is designed to operate at multiple speeds and is especially effective when paired with a fan controller.
The OcUK ZG3-120TL has been specifically chosen by OcUK Tech Labs to be the ultimate performance fan. The Golf III is an exclusive design only used by Zaward.
The new G3 Hexagonal dimple blade features an aerodynamic lift effect to raise airflow.
Dimension - 120 x 120 x 25mm
Fan Speed - 2000±200rpm
Bearing Type - Duro bearing
Max.Air Flow - 52.85 CFM
Noise Level - 30.9 dBA
Operation Voltage - 12V
Life Expectancy - 60,000 Hrs
Net Weight - 125g
Colour - frame: Solid Black ; Blade: White
Only £8.99 inc VAT.
ORDER NOW
Always worries me when shops start branding their own products, makes me concerned their advice won't be impartial.
Luckily we have these forums.
OcUK only seem to brand their budget lines so it isn't much of a problem. I doubt they would hesitate in recommending a product twice the price.
They look pretty cool. I'd imagine you could get rid of most the noise by putting them on 7v and have them going a little slower.
