*****OCUK FIFTH ROUND OF DEALS - MOTHERBOARDS*****
17 Oct 2002
Stoke
We've got a nice selection of Motherboards now that will partner Gibbo's latest CPU deals perfectly:
Asus P6X58D-E Intel X58 (Socket 1366) DDR3 Motherboard @ £162.98 inc VAT
This motherboard supports the latest Intel Core i7 processors in LGA1366 package with integrated memory controller to support 3-channel (6 DIMMs) DDR3 memory. The P6X58D-E breaks the boundaries to bring you the multi-GPU choice of either SLI or CrossFireX. The motherboard features a dedicated graphics engine on the most powerful Intel X58 platform to optimize PCIe allocation in multiple GPU configurations. Supporting next-generation Serial ATA (SATA) storage interface, this motherboard delivers up to 6.0Gb/s data transfer rates. Additionally, get enhanced scalability, faster data retrieval, double the bandwidth of current bus systems. Experience ultra-fast data transfers at 4.8Gbps with USB 3.0 - the latest connectivity standard. Built to connect easily with next generation components and peripherals, USB 3.0 transfers data 10X faster and is also backward compatible with USB 2.0 components. 16+2 phase power design, 16-phase for vCore and extra 2-phase for QPI/Memory controller inside CPU, can provide the highest power efficiency, and hence generates less heat to effectively enhance the overclocking capability.
- CPU: Intel Core i7 Processors (Socket LGA1366)
- Chipset: Intel X58 Express
- Memory: 6x DDR3 DIMM 2000(OC) / 1600 / 1333 / 1066 MHz (Max. 24GB) / Triple Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 3x PCIe 2.0 x16 Slots, 1x PCIe x1 Slots & 2x PCI Slots (Supports ATI CrossFireX & NVIDIA SLI Technology)
- Storage: 6x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 2x SATA 6Gb/s
- LAN: Marvell 88E8056 Gigabit LAN
- Audio: ALC889 8-channel High Definition Audio CODEC
- 8x USB 2.0
- 2x USB 3.0/2.0
- 2x IEEE 1394a
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
- 1x S/PDIF Out (Optical)
- 1x S/PDIF Out (Coaxial)
- 16+2 Phase Power Design
- TurboV
- MemOK!
- EPU
- Express Gate
- Fanless Design
- Stack Cool3+
- CrashFree BIOS 3
- EZ Flash 2
- MyLogo 2
Only £162.98 inc VAT.
ORDER NOW
Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard @ £151.99 inc VAT
Based on the Intel X58 chipset, the Gigabyte GA-X58A-UD3R delivers all the killer next generation features that gaming enthusiasts and power users have been waiting for including Gigabyte's 333 Onboard Acceleration features with support for USB 3.0, SATA Revision 3.0 (6Gbps) and a 3x USB Power Boost, as well as multi-GPU support for NVIDIA 3-Way SLI and ATI CrossFireX and support for Intel's high performance processors offering a high level of future CPU headroom for users wanting to maintain cutting-edge levels of performance. With the memory controller integrated directly into the processor die, the Gigabyte GA-X58A-UD3R also supports triple channel DDR3 memory for blazing fast memory performance.
- 2x USB 3.0
- 2x SATA 6Gb/s (RAID 0 and 1)
- Chipset: Intel X58 Express / ICH10R
- Memory: 6x DDR3 DIMM 2200 / 1333 / 1066 / 800 MHz (Max. 24GB) / Tri-Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 4x PCIe 2.0 x16 Slots, 2x PCIe x1 Slots & 1x PCI Slot (Supports ATI CrossFireX & NVIDIA SLI Technology)
- Storage: 1x Floppy, 1x Ultra DMA 133/100/66, 8x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 2x eSATA 3Gb/s
- LAN: RTL8111D Gigabit LAN
- 10x USB 2.0
- 3x IEEE 1394a
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
Only £151.99 inc VAT.
ORDER NOW
Asus P7P55D-E Intel P55 (Socket 1156) DDR3 Motherboard @ £112.99 inc VAT
This motherboard supports the latest Intel Lynnfield and Clarkdale processors, which have the memory and PCI Express controller integrated to support 2-channel (4 DIMMs) DDR3 memory and 16 PCI Express 2.0 lanes, enabling higher graphics performance. Supporting the next-generation Serial ATA (SATA) storage interface with onboard Marvell controller, this motherboard delivers up to 6.0Gbps data transfer rates. Experience ultra-fast data transfers at 5Gbps with USB 3.0 - the latest connectivity standard. Built to connect easily with next-generation components and peripherals, USB 3.0 transfers data 10 times faster and is also backward compatible with USB 2.0 devices. Turn on IO Level UP to boost the USB 3.0 or SATA 6Gb/s data transfer rate to up to 500MB/s. Users can flexibly switch between full-speed PCIe x16 mode for their graphics cards and IO Level UP for rapid data throughput.
- CPU: Intel Core i7/Core i5 Processors (Socket LGA1156)
- Chipset: Intel P55 Express
- Memory: 4x DDR3 DIMM 2200(OC) / 1600 / 1333 / 1066 MHz (Max. 16GB) / Dual Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 2x PCIe 2.0 x16 Slots, 3x PCIe x1 Slots & 2x PCI Slots (Supports ATI CrossFireX Technology)
- Storage: 1x Ultra DMA 133/100/66, 7x SATA 3Gb/s (RAID 0, 1, 5 and 10), 2x SATA 6Gb/s & 1x eSATA 3Gb/s
- LAN: RTL8112L Gigabit LAN
- Audio: VT1828S 8-channel High Definition Audio CODEC
- 2x IEEE 1394a
- 12x USB 2.0
- 2x USB 3.0/2.0
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
- TurboV EVO
- T.Probe Technology for Active Cooling
- ASUS 12+2 Phase Power Design
- Quad-GPU CrossFireX Support!
- MemOK!
- EPU
Only £112.99 inc VAT.
ORDER NOW
Gigabyte GA-P55-UD5 Intel P55 (Socket 1156) DDR3 Motherboard @ £114.99 inc VAT
The Intel brand new computing architecture based on the innovation of micro-architecture transforms 3-chip solutions to a 2-chip platform. The next generation Intel Core i7/ Core i5 processors with LGA1156 package integrate graphics and memory controller to support dual channel DDR3 memory. Supporting Intel Turbo Boost technology and Hyper-Threading Technology, Intel® Core i7/ Core i5 processors provide the overwhelming performance with optimized power efficiency. P55-UD5 support Intel Core i7/ Core i5 processors delivering native support for DDR3 memory up to 2200+MHz by the enhanced design of GIGABYTE, Intel Core i7/ Core i5 processors feature the memory controller integrated directly into the processor die, rather than as part of the Northbridge as in previous generations, allowing for faster memory performance.
- Memory: 4x DDR3 DIMM 2200 / 1333 / 1066 / 800 MHz (Max. 16GB) / Dual Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 3x PCIe 2.0 x16 Slots, 2x PCIe x1 Slots & 2x PCI Slots (Supports ATI CrossFireX & NVIDIA SLI Technology)
- Storage: 1x Floppy, 1x Ultra DMA 133/100/66, 10x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 2x eSATA 3Gb/s
- LAN: Dual RTL8111D Gigabit LAN
- Audio: ALC889A 8-channel High Definition Audio CODEC
- 3x IEEE 1394a
- 14x USB 2.0
- 1x PS/2 COMBO (Keyboard & Mouse)
- 12+2 Phase Design
- 2oz Copper PCB
- Smart6 (QuickBoot, QuickBoost, Recovery, DualBIOS, Recorder & TimeLock)
- Dynamic Energy Saver 2
- DES2 LED Hardware Design
- Smart TPM
- XHD (eXtreme HardDrive)
- AutoGreen
- Precision OV
Only £114.99 inc VAT.
ORDER NOW
Gigabyte GA-H55M-S2 Intel H55 (Socket 1156) DDR3 Motherboard @ £60.99 inc VAT
Introducing the H55M series of Gigabyte boards. Supporting the Intel H55 Express chipset for support for the Intel Core i3/i5/i7 (Clarkdale and Lynnfield) processors. The GA-H55M-S2 provides a brilliant entry level H55 Motherboard providing all the core feature neccessary in any motherboard. With intergrated graphics and support for up to 16GB of memory the GA-H55-S2 is packed with features.
- CPU: Intel Core i7/Core i5/Core i3/Pentium Processors (Socket LGA1156)
- Chipset: Intel H55 Express
- Memory: 2x DDR3 DIMM 1666+(OC) / 1333 / 1066 MHz (Max. 16GB) / Dual Channel
- Expasion slots: 1x PCIe 2.0 x16 Slot, 1x PCIe x1 Slot & 2x PCI Slot
- LAN: 1 x Realtek RTL8111E Gigabit LAN
- Audio: ALC888B 8-channel High Definition Audio CODEC
- 12x USB 2.0
- 1 x VGA
- 3 x Audio
- 2x PS/2 COMBO (Keyboard & Mouse)
Only £60.99 inc VAT.
ORDER NOW
Gigabyte GA-H55M-UD2H Intel H55 (Socket 1156) DDR3 microATX Motherboard @ £68.98 inc VAT
This motherboard supports the latest Intel Lynnfield and Clarkdale processors in the LGA1156 package, which has memory and PCI Express controllers integrated to support dual-channel (4 DIMMs) DDR3 memory and PCI Express 2.0 16x lanes providing higher graphics performance. Moreover, Intel Clarkdale integrated Graphics Processing Unit (GPU) processors together with Intel H55 chipset deliver a whole new experience of the next generation VGA performance. It also provides separated 3D, 2D and Video Engines to execute different graphic control in hardware.
- Memory: 4x DDR3 DIMM 1666+(OC) / 1333 / 1066 MHz (Max. 16GB) / Dual Channel
- Expasion slots: 2x PCIe 2.0 x16 Slot & 2x PCI Slot (Supports ATI CrossFireX Technology)
- Storage: 1x Ultra DMA 133/100/66 & 5x SATA 3Gb/s & 1x eSATA 3Gb/s
- 2x IEEE 1394a
- 12x USB 2.0
- 1x DisplayPort
- 1x HDMI
- 1x DVI
- 1x D-SUB
- 2oz Copper PCB
Only £68.98 inc VAT.
ORDER NOW
Gigabyte GA-G41M-ES2L Intel G41 (Socket 775) DDR2 microATX Motherboard @ £37.99 inc VAT
The GA-G41M-ES2L based on the Intel G41 chipset supports the latest Intel 45nm CPUs, creating a powerful multi-media platform which allows users to do more at once. At the heart of the Intel G41 Express chipset is the Intel X4500 graphics media accelerator, which support DX10 and features several unique innovations including more Execution Units for enhanced 3D performance and Intel Clear Video Technology for sharper images and precise color control.
- Revolution energy saving design with Easy Energy Saver Technology
- Supports 45nm Intel Core 2 multi-core processors with FSB 1333 MHz
- Dual channel DDR2 800 for remarkable system performance
- Integrated Intel Graphics Media Accelerator X4500 (DirectX 10)
- Features high speed Gigabit Ethernet.
- Home theatre quality 8-channel High Definition Audio
- Patented DualBIOS with dual hardware BIOS protection
Only £37.99 inc VAT.
ORDER NOW
Asus Crosshair III Formula AMD 790FX (Socket AM3) PCI-Express DDR3 Motherboard @ £124.98 inc VAT
The Crosshair III Motherboard supports the latest AMD Socket AM3 multi-core processors with unique L3 cache and delivers better overclocking capabilities with less power consumption providing you with more power and cheaper running costs. The AMD 790FX Chipset is designed to run up to 5200MT/s HyperTransport 3.0 interface speed and quad PCI Express 2.0 x16 graphics. It is optimized with AMD's latest AM3 and multi-core CPUs to provide excellent system performance and overclocking capabilities. Native DDR3 1600(O.C.) support provides faster data transfer rate and more bandwith to increase memory computing efficiency, enhancing system performance in 3D graphics and other memory demanding applications.
- AMD Socket AM3 (Phenom II/Athlon II/Sempron 100 Series Processors)
- AMD 140W CPU Support
- AMD Cool 'n' Quiet Technology
- Supports 45nm CPU
- AMD 790FX/SB750
- Up to 5200 MT/s; HyperTransport 3.0
- 4 x DIMM, Max. 16 GB, DDR3 1600(OC)/1333/1066
- 2 x PCIe 2.0 x16
- 3 x PCIe 2.0 x1
- 1 x PCI 2.2
- Gigabit LAN controller, featuring AI NET 2
- SupremeFX X-Fi Audio Card
- 2 x 1394a ports
- 12x USB 2.0 ports
- Asus MyLogo 3
- Asus EZ Flash 2
- Asus CrashFree BIOS 3
- Q-Connector
- Asus Q-Fan 2
- External LCD Poster
- Asus Q-Shield
- AMD OverDrive Support
- Asus TurboV
Only £124.98 inc VAT.
ORDER NOW
