hi
I've had an OC PC for almost 2 years, but having an issue with it not booting at all, not even to bios. Lights come on, fans spin up but blank screen/no display. I've been able to switch out and test different memory and graphics card and also reset the bios, but still the same. I have noticed an orange light in the bottom corner that slowly blinks, but dont recall if that is normal.
Only thing I cannot swap out is the power supply. Anything I can do to test that is the fault, or anything else I can try or look into?
Any help appreciated.
Components:
OcUK Gaming Firefly Plus - Intel 10th Gen Core i5/i7 Gaming PC
CA-02Q-KK Kolink Core Series 700W 80 Plus Certified Power Supply 1
CA-07M-PT Phanteks Digital RGB LED Strip - Combo Set 1
CA-09L-PT Phanteks Eclipse P360X Midi Tower DRGB Case - Black 1
CP-683-IN Intel Core i5-10600KF 4.10GHz (Comet Lake) Socket LGA1200 Processor - Retail 1
GX-1C7-GI *Build Stock* Gigabyte GeForce RTX 3070 Gaming OC 8GB GDDR6 Graphics Card 1
HD-384-SE Seagate BarraCuda 1TB 7200RPM SATA 64MB Cache Hard Drive - *System Stock* 1
HD-3BC-SE Seagate Firecuda 510 2TB PCIe NVMe M.2 Solid State Drive (ZP2000GM30021) 1
MB-6EL-AS Asus Prime Z490-P (Socket LGA 1200) DDR4 ATX Motherboard 1
MY-0AA-TG Team Group Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Chan
Components:
will look into that
