** OcUK FIRST IN EUROPE WITH DDR4!! **
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
OK its not of much use right now but as always OcUK is leading and will lead the way on DDR4 solutions for Intel's new and upcoming flagship X99 solution.
We are in talks with Corsair, Teamgroup, GeIL and G.Skill for DDR4 solutions.
To start the ball rolling Crucial will be available very soon and you can pre-order now, though I do advice against it, wait until nearer the time as pricing might drop some more.
Crucial Ballistix Sport 32GB (4x8GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit (BLS4K8G4D240FSA) @ £359.99 inc VAT
Designed for performance enthusiasts and anyone who simply wants to get more out of their system, Crucial Ballistix Sport performance memory helps you do just that. Give your processor the resources it needs to perform and make your computer faster and more responsive.
Memory is fun when it’s faster, when it’s stylish, and when it helps your system perform at a higher level. Compared to standard PC memory, that’s exactly what Ballistix Sport is engineered to do. Get faster speeds and run demanding applications with ease. Multitask at will with increased bandwidth. Strike first with better latencies and reduced load times. And achieve seamless responsiveness with exciting and affordable performance.
Getting more out of your system should be easy—and that’s exactly how we engineered Ballistix Sport memory. Featuring intuitive module designs, Intel® XMP profiles1 and more, we designed Ballistix Sport with the sole intent of creating affordable, easy-to-use performance memory. Installation is a cinch: just plugand-play, and get ready to win with little to no BIOS configuration.
Ballistix Sport performance memory is available in a wide range of module types, configurations, and heat spreader options. Sport modules are available in UDIMM/SODIMM form factors, DDR3/DDR4 memory technology, and tall/short height profiles. Pack more performance into nearly every type of system – yours included.
As a brand of Micron, one of the largest memory manufacturers in the world, Ballistix memory is built to last and delivers a higher level of performance than standard memory. For more than 35 years, we’ve engineered old-school DDR memory all the way to Ballistix Sport DDR4, which empowers you to seize an
affordable performance edge. Backed by a limited lifetime warranty2 and rigorously tested to some of the most demanding standards in the industry, Ballistix Sport performance memory has been thoroughly proven and is ready to make an impact in your system.
Features:-
- Speeds start at 2400 MT/s and faster speeds are expected to be available as DDR4 technology matures
- Faster speeds and responsiveness than standard Crucial DDR4 memory
- Four channel memory architecture maximizes data rates
- Integrated heat spreader and black PCB
- Easy plug-and-play installation
- Intel® XMP 2.0 profiles for easy configuration1
- Optimized for the latest Intel X99 platforms (X99 Platform required)
- Limited lifetime warranty
Specification:-
- 2400MHz (PC4-19200)
- CAS Timings: 16-16-16
- Voltage: 1.20v
Only £359.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit (BLS4K4G4D240FSA) @ £179.99 inc VAT
Features:-
Specification:-
- Voltage: 1.20v
Only £179.99 inc VAT.
ORDER NOW
Crucial 32GB (4x8GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K8G4DFD8213) @ £329.99 inc VAT
In the ever-changing world of technology, any component more than half a decade old is usually in need of an update. At seven years old and counting, that’s exactly the state DDR3 memory is in: computers can only do so much with it.
Since the introduction of DDR3 memory technology in 2007, processors have doubled in capability, SSDs have revolutionized throughput, and graphics cards have drastically increased frame rates, leaving memory as a limiting factor. With Crucial DDR4 Desktop Memory, crush the DDR3 memory bottleneck and unlock a new standard of performance.
Load applications faster and run demanding programs without lag. Crucial DDR4 memory debuts at 2133 MT/s – more than 30% faster than DDR3 memory technology.1 Even better, as DDR4 technology matures, speeds are projected to hit 3200 MT/s – twice what was possible on standard DDR3 memory.
Effortlessly multitask between apps, and empower your system to fire on all cylinders. Crucial DDR4 increases memory bandwidth by over 30%, allowing your system to handle more data at once. As DDR4 technology matures, bandwidths are expected to achieve up to 25.6 GB/s – twice that of standard DDR3. To maximize bandwidth, Crucial DDR4 memory is optimized for nextgen platforms that support four channel memory.
Get better performance – using less power. Operating at just 1.2V compared to 1.5V for standard DDR3 memory, Crucial DDR4 consumes 20% less voltage than standard DDR3 technology. Crucial DDR4 modules also contain other efficiency features, for an overall power reduction of up to 40%.
As a brand of Micron, one of the largest memory manufacturers in the world, Crucial DDR4 memory represents the future of computer performance. From the original DDR technology to DDR4, we’ve engineered the memory technologies that have powered the world’s computers for 35 years and
counting. When you choose Crucial DDR4 memory, you’re choosing memory that’s backed by a limited lifetime warranty2 and designed for the world’s leading systems. Don’t settle for anything less.
Specification:-
- 2133MHz (PC4-17000)
- Voltage: 1.20v
- Warranty: Lifetime
Only £329.99 inc VAT.
ORDER NOW
Crucial 16GB (4x4GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K4G4DFS8213) @ £169.99 inc VAT
Specification:-
- Voltage: 1.20v
Only £169.99 inc VAT.
ORDER NOW
Get saving as X99 is Intel's flagship desktop gaming platform, the new CPU's will feature upto 16 threads on desktop (more on Xeon) so this platform will offer a serious performance advantage.
The other main advantage is the CPU especially on Extreme with the amount of PCI-E lanes. :)
£180 is not too bad for 16GB. Will wait for Corsairs memory and prices, but its not as bad as I thought it was going to be.
Not too bad considering its THE FIRST listing.
get 4-5 other companies up there and it will come down nicely.
Give it 6 months and We'll see some nice kit. Can't wait!
I reckon the prices will come down before the motherboards and CPU's are available, so don't buy yet. :)
Hi there
Now for the fast stuff!!!
Hi there
Now here comes the mega fast stuff:-
Crucial Ballistix Elite 32GB (4x8GB) DDR4 PC4-24000C15 3000MHz Quad Channel Kit @ £666.66 inc VAT
In the final days of DDR3 technology, heavily overclocked performance memory topped out at around 3000 MT/s. However, in order to achieve this, you needed the right processor, the right motherboard, a PhD in overclocking, and the willingness to surrender everything in your wallet. Not anymore.
Crucial® Ballistix® Elite DDR4 memory cracks the DDR3 performance limit and debuts at 3000 MT/s – and that’s just getting started. Feed your 8-cores and draw upon the fastest speeds and bandwidths available.
While your opponents fight petty using DDR3-1600 MT/s, obliterate them with Ballistix Elite DDR4 speeds up to 3,000 MT/s and get even faster as the technology matures. Alongside these speed gains, draw on the improved responsiveness, increased frame rates, and optimized latencies of Ballistix Elite DDR4 technology and revel in an unreal gaming experience.
Flood your memory bandwidth and process up to 24 gigabytes per second – a feat that’s nearly impossible to achieve with DDR3 memory. Leveraging the faster burst access speeds that are only possible on DDR4 architecture, Ballistix Elite DDR4 maximizes performance with four channel memory.
Ballistix Elite DDR4 memory leverages the latest advancements in efficiency technology and is engineered to run at lower voltages for inherent energy gains. Coupled with a thermal sensor and our high-end Ballistix M.O.D. utility for real-time temperature monitoring to aid in overclocking, Ballistix Elite DDR4 can wring up to 40% more power efficiency out of your memory.
Give your rig a next-gen facelift with an aggressively styled black anodized heat spreader that is just as menacing as your gameplay, and a glimpse of a black PCB that bodes well for any color scheme. Optimized for the latest Intel® X99 boards with support for XMP 2.0 profiles, Ballistix Elite DDR4 module set up is easy: just lock and load your BOIS and get ready to win.
Features:-
- Speeds start at 2666 MT/s and faster speeds are expected to be available as DDR4 technology matures
Specification:-
- 3000MHz (PC4-24000)
- CAS Timings: 15-15-15 TBC
- Voltage: 1.20v
Only £666.66 inc VAT.
ORDER NOW
Crucial Ballistix Elite 16GB (4x4GB) DDR4 PC4-24000C15 3000MHz Quad Channel Kit @ £329.99 inc VAT
Features:-
Specification:-
- Voltage: 1.20v
ORDER NOW
Crucial Ballistix Elite 32GB (4x8GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit @ £479.99 inc VAT
Features:-
Specification:-
- 2666MHz (PC4-21300)
- Voltage: 1.20v
Only £479.99 inc VAT.
ORDER NOW
Crucial Ballistix Elite 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit @ £239.99 inc VAT
Features:-
Specification:-
- Voltage: 1.20v
Only £239.99 inc VAT.
ORDER NOW
What's wrong with the latency on these Cas 16? Teamgroups budgetish 2666MHz DDR3 is Cas 11.
Those are also single sides Mfr dimms, to be blunt absolute poo performance, these ddr4 dimms (as confirmed by 8 pack) are dual sided micron ic. Nothing in the ddr3 range will touch the ddr4 2666+ kits.
In the grand scheme of ddr, these are relatively well priced.
its the next step up from ddr3 so timings wont matter if they look super loose
r.i.p ddr3 better grab it before it goes eol
Production started winding down a while back on ddr3...prices will only get higher as it slowly vanishes from stores.
How are single side slower than dual side?
Are there no dual sided DDR3 modules?
