Hi Guys
We have the First UK Stock availability of the new T150RS from Thrustmaster.
This wheel is similar in features to the XBOX orientated TX Racing but with a much more affordable price tag.
The T150 comes in the plain and Ferrari branded flavours and looks pretty epic given the price.
Perfect for PS3, PS4 and PC users.
Official Racing Simulator For Playstation 4 And Playstation 3 (Also Compatible With Pc). 1080 Force Feedback Racing Wheel. Built-In PS4/PS3 Sliding Switch. Realistic 11"/28 CM Wheel. Large Pedal Set Included.
PlayStation 4 certified embedded software and PS4/PS3 sliding switch.
Official embedded software: the racing wheel is automatically recognized by the PS4 console.
Compatible in the console's menus.
PS4/PS3 sliding switch for optimal compatibility on both systems
1080 force feedback base featuring Immersion TouchSense technology.
Drive system with adjustable Force Feedback lets you feel every detail while you're racing - the road or track's relief, loss of tire grip, braking, bumps and impacts, etc.
Rotation angle adjustable from 270 to 1080!
Very precise wheel: optical reading with 12-bit resolution (i.e. 4,096 values on the wheel's steering axis).
Mixed belt-pulley and gears system. Smoother, more fluid and less noisy than helical gears with metal ball-bearing axle (for enhanced sturdiness).
Internal memory and upgradeable firmware.
Robust and versatile attachment system, compatible with all mounts (desks, tables, etc.).
Large, optimised pedal set
Pedals with wide foot rest.
Each pedal's angle of inclination can be adjusted
Brake pedal with progressive resistance
Realistic wheel
Built-in official buttons for PlayStation 4 (PS/SHARE/OPTIONS)
Access social functions, switch between the game and the system, navigate through the console's menus, etc.
11"/28 cm in diameter, with an ergonomic design perfectly adapted for all driving games
Rubber-coated wheel grips
2 large, wheel-mounted sequential paddle shifters
5"/13 cm tall - 100% metal - Tact switch with life cycle exceeding 500,000 activations
Comprehensive driving gear
13 action buttons (including 2 on the base) + 1 D-Pad
Features:
- 1080 force feedback racing wheel
- Built-in PS4/PS3 sliding switch
- Realistic 11"/28 cm wheel
- Large pedal set included
- Drive system with adjustable Force Feedback lets you feel every detail while you're racing
- Rotation angle adjustable from 270 to 1080!
- Internal memory and upgradeable firmware
- Rubber-coated wheel grips
- 2 large, wheel-mounted sequential paddle shifters
- Each pedal's angle of inclination can be adjusted
- Brake pedal with progressive resistance
Thrustmaster T150 RS Force Feedback Wheel (PS4/PS3/PC) @ £169.99 inc VAT
Only £169.99 inc VAT.
ORDER NOW
Thrustmaster T150 Ferrari Force Feedback Wheel (PS4/PS3/PC) @ £169.99 inc VAT
ORDER NOW
Realistic wheel
Features:
ORDER NOW
ORDER NOW
