OcUK FIRST UK STOCKIST OF THE COOLERMASTER HAF 912 PLUS CASE
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
I have done it again, secured all the UK stock on the latest Coolermaster case. The HAF 912 Plus. All backorders are shipping today with limited stock still available.
Coolermaster HAF 912 Plus Case - Black @ £69.99 inc VAT
Cooler Master adds another new member to the HAF series, the HAF 912 Plus. To carry the mission of providing the best thermal solutions, HAF 912 Plus supports two 120 mm for external radiator and high-end CPU coolers. Furthermore, the spacious interior accommodates two 200mm fans and two-- 120mm fans for better and superior airflow yet, enough to fit 12 devices and high-end GPUs such as Radeon HD5970 and Nvidia GTX 480.
- Superior cooling performance support up to two 200 mm and two 120 mm fans
- Front 200mm fan with brilliant Red LED provides the best airflow to HDDs
- Removable 3.5”HDD cage provides enthusiasts more convenient installation
- Customized neat cable management
- Dimensions 230 x 480 x 496 mm (WxHxL)
- Weight: 8,45 kg
- Motherboard Support: ATX, Micro-ATX
- Front Cooling: 1x 200 mm (19 dB(A), 700 RPM, Red LED) or 2 x 120mm fans (optional)
- Top Cooling: 1x 200 mm or 2 x 120mm fans (optional)
- Rear Cooling: 1x 120 mm (17 dB(A), 1.200 RPM)
- Side Cooling: 1x 140 / 120 mm (Optional)
- 5.25" Drive Bays: 4
- 3.5" Drive Bays: 7
- 2.5" Drive Bays: 4
- Expansions Slots: 8
- Front I/O Ports: 2x USB 2.0 / 1x eSATA/ 1x Audio In/Out
- VGA Card Size: Up to 39 cm
Only £69.99 inc VAT.
ORDER NOW
Front intake has dual layer meshing thus providing a filter effect
5.25" bays have dust filters.
Rear and top fans are exhaust so no filters.
Very nice budget case. With lots of features i hope there are some in stock when it comes to replacing my case.
I like the look of this case, mind, if thats the reset button next to the power, it might be abit of a confusion :)
