OCUK Forum RGB values.
7 Apr 2009
Western Seaboard
Does anyone know the RGB values for the blue/teal colours shown here ?
The reason I ask is that I screen grabbed what you see, opened it in photoshop (converting embedded profile to adobe rgb) and saved my work
(sigs) in sRGB
As you can see, my sig is "off colour". :( Any ideas ?:confused:
Well I'm not sure what you did wrong, but the values you want are:
Dark blue: R: 0, G: 51, B: 102 | #003366
Lighter blue: R: 28, G: 87, B: 128 | #1C5780
you can download apps that give you the RGB of what ever you point at
or set the background to transparent ?
MW
Probably some colour management thing, Illustrator always seems to give me different colours to Photoshop for example. Which is annoying.
As far as I remember those no.s are the ones I used ???
Setting your background to transparent has got to be the easiest way?
I used the Mac DigitalColour Meter
Transparency's the key :)
Yes and I've done this before with colour samples etc and it worked perfectly.
If I were from the US I think I'd be saying "go figure", but I'm not so I won't.
Thanks chaps :)
