** OcUK H²Flo Liquid CPU Cooler with Gelid Silent 120mm Quiet Fan - Bundle £43.99inc VAT **
20 Jul 2009
The bleak North East arm pit of Britain
Hello
The OcUK H²Flo Liquid CPU Cooler is now available in a bundle offering performance that will match and ever better the competitives in the market. Built to the same high quality standard the OcUK H²Flo Liquid CPU Cooler Bundle is priced up to 30% lower offering all of the benefits and performance without the high price tag!
:D
OcUK H²Flo Liquid CPU Cooler with Gelid Silent 120mm Quiet Fan (Socket LGA1366/1155/1156/775/AM2/AM3) @ £43.99 inc VAT
The OcUK H²Flo Liquid CPU Cooler is a fantastic product aimed at medium to high end CPU cooling, with the power to slay any overclocked CPU temperatures succesfully. The cooler houses a large surface cold copper plate to ensure all the heat is drawn away from your CPU and transferred to the sealed liquid and the pump then transports the liquid round to the radiator which then cools the liquid back down to enable the liquid to recirculate back to your CPU block to again pull more heat away. All you need to do it add a fan of your choice to the radiator and your CPU will be cooler than the next Ice Age.
- Socket LGA1366 / 1155 / 1156 / 775 / AM2 / AM3
- Radiator Dimensions: 120mm x 152mm x 27mm
- Fan Support: 120mm x 25mm
- Cold Plate: Copper
- Radiator Material: Aluminium
- Thermal paste is pre-applied
Designed for Silent enthusiasts GELID Silent case fans provide additional airflow without increasing noise levels and at affordable price. Precisely balanced fan blades and long life Hydro Dynamic bearing guarantee ultra low noise. Furthermore, fan mounts replace traditional screws which are made of high quality, temperature resistant, extra long lasting rubber. They are designed to stop vibrations from the fan motor transferring into your PC case.
- Silent Operation
- Optimised Fan Blades
- High Airflow and High Static Pressure
- Rubber Fan Mounts
- Long Lifetime
- Air Flow (CFM): 37
- Bearing Hydro Dynamic Bearing
- Cable Length (mm): 500
- Connector: 3 Pin Molex
- Dimensions (mm): 120 x 120 x 25
- Fan Speed (RPM): 1000
- Noise Level (dBA): 20.2
Only £43.99 inc VAT.
ORDER NOW
Currently this Bundle saves you £2.00 inc VAT however this will increase to £10.00 inc VAT when the parts are not on "This Week Only"
Your getting a H60 with a better fan for only £44 :)
Sounds like a good plan to me. Shameless steal of my cooler to sell your fans though Andrew Moore - I like it!
