the most likely cause is that you bought a really loud fan. however, it might be caused by you plugging the pump into the wrong socket, as this needs 100% power at all times. or, you might have some air flowing through the pump
I've just worked it out, after fiddling around with it. I plugged the pump into the PWR Fan socket. If you want to keep it simple you are going to need a PWM Fan for the radiators so it can automatically detect when it needs to raise or lower fan speed which plugs into the CPU fan pin.
