** OCUK HASWELL COOLING **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Haswell is almost upon us and I have taken the time today to update our heatsink listings to include Haswell compatibility on the titles.
If a heatsink is compatible with 1155/1156 then it is also 1150 compatible.
CPU COOLER RANGE
Every product in the heatsink range has a full socket compatibility list in its title making it easy for you to check if your heatsink is going to work with the new Haswell platform.
Some highlights from our range that we have found to work exceptionally well with Haswell include:
Alpenföhn K2 Mount Doom CPU Cooler (Socket 775 / 1150 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £59.99 inc VAT
ORDER NOW
Phanteks PH-TC12DX CPU Cooler - Silver (Socket 775 / 1150 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £39.98 inc VAT
Only £39.98 inc VAT.
ORDER NOW
Prolimatech Megahalems Rev C CPU Cooler (Socket 775 / 1150 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £42.98 inc VAT
Only £42.98 inc VAT.
ORDER NOW
In addition to our superb Heatsink range, we have also added compatibility lists to our Watercooling range.
As with the heatsinks, any 115x compatible CPU block is 1150 - Haswell compatible.
Watercooling offers the ultimate in 24/7 cooling performance for your new Haswell CPU and enables you to reach new heights of overclocking headroom.
All Overclockers UK Tech Labs Kits are Haswell compatible
TECH LABS WATERCOOLING SOLUTION RANGE
We also have an updated CPU Block range with every Haswell compatible block being updated in the item description to show that it works with the new platform.
Any Questions, just ask and I will do what I can to help
Rich
well it does, because if we didn't update our listings to include compatibility for 1150, then i would imagine we would be inundated with questions about cooler compatibility.
just because you know it fits doesn't mean 99% of the rest of our customers won't be asking the questions.
its just trying to be helpful and i am sure a lot of people will appreciate the information.
