OcUk laptop trackpads
26 Dec 2003
I am looking at Haswell laptops and like the look of the OcUK Gamer W350STQ, my main questions regards the quality of the trackpads, there must be a few on here that have bought these OcUk laptops, how do you find them?
Fine for prolonged use.
I tend to use a mouse with mine most of the time but when I've had to use the touchpad I've had no issues.
It's actually better than my previous HP laptop which would jerk around all over the place. Movement is smooth and precise.
Thank you for your reply, I have read through several of your posts about your OcUk laptop and I have now ordered one too.
I went for the Gamer W350STQ 15.6"
Thanks again,
Robert
No worries :)
I can't fault mine. It might be a bit too big wue to the 17" screen and I probably should have gone for the 15" version but at the time the 17" was on offer so thought sod it ha
BTW if your into overclocking and reach the limits on your 765mb I may be able to unlock the bios for you.
