OCUK - Mistake
great reliable long lasting 140mm fan with near silent perfomance to boot.
- Model - D12SL-12
- Dimensions - 120 x 120 x 25 mm
- Voltage - 12 Volts
- Speed - 1000 RPM
- Noise Level - 25 dB (A)
- Connector - 3-Pin
- Bronze Bearings
140mm in discription
in the title it does say 120mm fan, but i can see how you could become confused with it saying 120mm in one place and 140mm in another.
you've also reminded me of another mistake on the Prolimatech Genesis Mega Performing CPU Cooler
its really not important atall, but its kinda funny
Light weight at 800 kgs (without fans) in the highend class
800kg :eek:
dont think my motherboard could take that
Shall look into this in the morning for you, I shall check it physically. :)
(Pretty sure it is a 120mm, but will double check to make sure and update the website).
