Hi guys
Ive just put a system together using one of OCUK's OC Bundles.
http://www.overclockers.co.uk/showproduct.php?prodid=BU-042-OE&groupid=43&catid=339&subcat=
If you scroll down to one of the reviews, there is a guy who is having the same problem as me. Basically the OC has knocked out the use of the on board graphics. When installing Intels HD graphics driver the PC freezes up and BSODS. I have to get back into Windows 7 in safe mode and delete the driver for the PC to work again. Windows 7 does find a display driver but you cannot use the correct resolution. Everything is displayed massive.
I know I can buy a graphics card like the guy in the review did to get around the problem but the PC was built to a budget for a friend and they really don't want to fork out anymore £££. I thought these packages would have been tested for this kind of thing?
Any suggestions appreciated.
Cheers
Cheers
