OCUK Online Store Build Advice
13 Oct 2019
Hi guys/girls,
I hoe someone can help. I saw a build on the website, namely the:
OCUK TECH LABS AMD RYZEN MIDI TOWER GAMING PC CONFIGURATOR
Anyway, a couple of things I would like to do I cannot configure for example remove all the drives that I can select and only then have 500GB M2.
Also, I would like a power supply that only has braided cables showing inside the case or a least a PSU that can take coloured braided cable fitted by OCUK.
Is this something I can contact the sales department to reprice or is it set to what you choose?
Would be shame as a nice system.
Thanks for any help in advance.
Scott.
I'm sure they'll build you whatever you want as long as all of the parts are compatible. They can't have every possible option available in the configurators.
That would be awesome thanks I will give them a phone tomorrow and might even ask them if they would do a Jonsbro C5 case build for me. Not to everyones taste but I just think that brushed metal look is cool as.
Thanks a lot.
Thanks a lot.
Overclockers will build you a pc to whatever spec you require just pick the parts and ask them how much.
Not sure of you get the same warranty as a pre built system but ask the question.
