Hi Guys
From today onwards we are proud to announce a new range of optical media.
We carry the latest ranges from market leading brands such as the massively well known TDK and the ultra reliable Verbatim.
Take a look at the new range HERE, we are expanding the range further over the coming weeks with improved budget lines under the OcUK Value moniker.
If there is a favourite of yours that you use regularly or if you would like us to stock a certain line then let us know here and we will do everything we can to stock it.
Expect regular deals, Savings and TWO offers for all optical media from now on, so keep checking the section for
Here are some of our hot sellers and a pick of the best for you:
5 Pack - TDK Blu-ray BD-R (4x) 25GB 5P FJC (T78008) @ £9.71 inc VAT
These discs, branded as "TDK Life on Record" are capable of storing 25GB of data or 135 mins of HD video.
Key Features
• 25GB capacity
• 4x recording speed
• 5 pack
• Supplied in standard Jewel cases
TDK Blu-ray discs, featuring DURABIS2™ technology, make recording HD video and backing up large data directories possible. Each single layer 25GB disc provides 5x the storage of a conventional DVD allowing for 2 hours of HD quality video while supporting a throughput of 72Mbps.
The exclusive DURABIS hard coating formulation protects the media
surface against scratches and other contaminants while the advanced
spin coat manufacturing process and ultra-precise recording materials
create an extremely smooth and precise cover layer allowing for 10,000 re-writes without loss of quality.
Only £9.71 inc VAT.
ORDER NOW
1 Pack - Verbatim BD-R 6x 25GB Blu-ray Print J/C (43712) @ £3.98 inc VAT
BD-R SL 25GB 6x Printable Single Jewel Case The advent of Blu-ray technology has led to the introduction of high capacity storage discs to meet the demand cause by the rapid growth of high definition television (HDTV).
Key Features
• Hard Coat protective layer
• Extremely long archival life
• Excellent playback performance
• BD-R is for use in BD drives and recorders
• Laser Wavelength: 205nm
Blu-ray discs get their name from blue laser technology. The shorter wavelength of the laser is the reason it is blue in colour. The blue laser has a wavelength of 405nm compared with the wavelength of 650nm for DVD which utilises red laser technology. The benefit of having a blue laser with a shorter wavelength means it is possible to write smaller data pits and therefore vastly increase the amount of data on the disc.
Blu-ray discs offere 3 to 5 times the storage capacity of a standard recordable DVD disc, enabling the recording, rewriting and playback of high definition video (HD).
Only £3.98 inc VAT.
ORDER NOW
50 Pack - Datawrite Titanium 16x DVD-R 4.7GB FF Printable @ £8.99 inc VAT
Datawrite Titanium full face printable DVD-R discs are a fantastic way to put a great final touch to a presentation or media disc. Present with style and add that little bit extra.
- Full face printable
- High quality dye which means that all hardware will be able to make good quality, long lasting recordings of video/data/music.
- Datawrite have paid particular attention to the quality of the polycarbonate layer (the middle section of the disc). This will improve the discs long term performance.
- The top of the disc is protected by the titanium coloured top surface.
These discs have a titanium (dark grey) coloured top surface featuring the Datawrite logo and a pre-lined area for content labelling.
Only £8.99 inc VAT.
ORDER NOW
25 Pack - Verbatim DVD+R DL 8x (43667) @ £23.99 inc VAT
Verbatim Double Layer Discs provide a massive 8.5GB (2.6 for 8cm products) storage capacity. The double layer of recording has been made possible by the creation of a new substrate layer that sits in between each recording layer, that allows the laser beam to record on both layers. Once the first layer has been recorded, the laser re-focused to record on the second layer.
Specifications :-
- Write-Once Double Layer DVDR
- 8.5GB Native Capacity
- 8x Write Speed
- Spindle
- Matt Silver Disc Surfacer
Only £23.99 inc VAT.
ORDER NOW
25 Pack - TDK CDR-80 52x 25pc Cakebox (T18767) @ £4.99 inc VAT
Developed for ultimate performance, and manufactured to the most exacting standards, TDK CD-R media is the ideal digital storage solution. CD-R disks are write once, meaning a CD-R can be fully recorded one time, but can't be erased or rerecorded.
Key Features
• Write-Once CDR
• Native Capacity 700MB
• Write Speed 52x
• Package Type Spindle
• Disc Surface Silver
Only £4.99 inc VAT.
ORDER NOW
100 Pack - Datawrite CD-R x52-Speed 700MB @ £12.98 inc VAT
CD-R - 700MB - 52x Write Speed - Cakebox - 100 Pack
- Manufacturer: Datawrite
- Max Write Speed: 52x
- Max Storage Data: 700MB
- Max Storage Time: 80min
Only £12.98 inc VAT.
ORDER NOW
OcUK Sandwich CD Case - 24 Discs @ £3.98 inc VAT
For years, the OcUK burger was world renowned as the market leader in optical media storage and transportation. The OcUK Sandwich gives all of the benefits of the OcUK burger in a new healthy package.
The OcUK Sandwich is the perfect storage solution for your media. Holding 24 Discs in a tasty exterior. The OcUK Sandwich gives you everything you need to store your CDs, DVDs and BluRay discs in a delicious, soft outer case.
• Durable Zip for security
• Healthy Fillings
• 24 Disc Capacity
• No Nutritional Supplements Required
• Calories - 0
• Total Fat - 0g
• Saturated Fat - 0g
• Cholesterol - 0mg
• Vegetarian Friendly
Only £3.98 inc VAT.
ORDER NOW
Key Features
• 25GB capacity
• 5 pack
Only £9.71 inc VAT.
ORDER NOW
Key Features
Only £3.98 inc VAT.
ORDER NOW
Only £8.99 inc VAT.
ORDER NOW
Specifications :-
- 8x Write Speed
- Spindle
ORDER NOW
Key Features
• Write-Once CDR
• Write Speed 52x
Only £4.99 inc VAT.
ORDER NOW
ORDER NOW
• Healthy Fillings
• 24 Disc Capacity
• Calories - 0
• Total Fat - 0g
• Cholesterol - 0mg
Only £3.98 inc VAT.
ORDER NOW
