- 26 Jul 2004
- Nr London
After having my first overclocked bundle RMA'd (the mobo failed) it was replaced with a newer mobo and the core i7 930, overclocked to 4Ghz.
Problem is this is not stable. It will boot into Windows fine, but then after a while applications lock up, then slowly every locks up. Reboot a few times, same problem. Then the mobo reports that problems have occured due to overclocking etc and resets to stock speed. Cooling is not an issue here and my power supply is fine. At stock speed the machine is perfect and very nippy.
I have paid a bit more for the overclocking and it simply doesnt work. Its great that it boots to windows at the overclocked speed,but I doubt they do any longer term stability testing.
Do Overclockers include this in the warranty as the components are not faulty, it is a config issue?
