Time has come to buy a new pc to replace my current P4 system.
I've been reading these forums for quite a long time and think i'm confident enough now to build a pc myself but i'd rather not have my first attempt at it with such an expensive budget so have been looking at the OCUK pre built systems.
I've got around £1200 to spend on just the hardware, won't need monitor, mouse, keyboard, speakers or soundcard though.
I've decided on this
http://www.overclockers.co.uk/showproduct.php?prodid=FS-005-OC
Would just like to double check this spec before buying, basically i'm a pretty keen gamer, using a 24 inch monitor and i'd like to be able to play all the newest games at 1900x1200 such as crysis, bioshock etc without any problems.
System is going to need to last for another 2-3 years and just like some opinions from you guys that this system will do the job ?.
I'm not interested in changing to vista yet either, so sticking with the 2gb ram option would also be better i assume ?
Thanks in advance
Thanks in advance
