OCUK Pre-built systems - quick question on new specs
Status
Not open for further replies.
18 Oct 2005
Just saw the update on the OCUK website indicating that the specs for their pre-built systems have been improved and prices lowered. I had a quick look at the overclocked range but can't seem to see where the changes have been made. Can anyone point out the what specs have been improved and by how much prices have dropped as I in the market to buy and a system from this range is a serious contender for me. Thanks for your help.
I doubt anyone except shop employees will have a record of what the machines used to include, so as to compare and generate a changelog. Your best bet would probably be a phone all to OcUK.
I bought one of the Ultima OC 8800GTX systems last year (6 months ago) and the only thing that's changed on the spec is the overclock has been lowered slightly (3.4 to 3.3).
Other than that the price is a bit lower (c. £100).
Point noted - just thought maybe an admin here might have known, maybe if they worked at the shop.
Have you enjoyed your system?
Very much so. No major issues at all.
I wanted an overclocked sytem but didn't have time/balls to build one and didn't want to spend cash on decent parts for my first overclock to only go and bork them all.
There's no doubt you can save yourself maybe £150'ish by building it yourself but frankly for that kind of saving, I'd much rather have someone else do it and give me a warranty too!
I have also been following the shop announcement re spec and price and cannot see any change. I have been watching existing specs for a while.
Can someone from the shop comment.
See, I knew I wasn't imagining it. Will send a webnote - usually gets a quick response
Some systems have been changed more than others and the whole section is being improved as a whole.
Just drop a webnote or a call and you will get a answer.
Status
