OCUK Revamped RAM Range
4 Dec 2015
London
Kudos to the team at OCUK the range is becoming much more diverse - but why hasn't it been posted? I've just bagged some of the new Kingston sticks elsewhere but I can see most of that new range (Working well on Ryzen) and the G.Skill coming in (small numbers).
So good work but you should be shouting about this, or I missed it :)
Adding 8Pack:
https://www.overclockers.co.uk/pc-components/memory/ddr4?sSort=2&ckSuppliers=432&ckTab=0
G.Skill:
https://www.overclockers.co.uk/pc-components/memory/ddr4?ckSuppliers=238&ckTab=0&sSort=2
Kingson:
https://www.overclockers.co.uk/pc-components/memory/ddr4?ckSuppliers=324&ckTab=0&sSort=2
If anyone OCUK should read this - any chance you're going to stock the 4000mhz Kingston? Doesnt seem to be in the UK at all just yet but in future...
Cheers
i noticed them earlier, dont know why but i prefer the kingston ram. its more discreet and not right in your face
It's not a crime to not want LEDs on your DIMMs :) Nothing wrong with favouring a manufacturer who caters to opaque-cases and keeps the costs down in the process.
G.Skill:
Kingson:
Cheers
Kingston won't let us list it yet, still testing, as soon as they give the go ahead, it shall be listed.
Right now the best memory we sell is the 8 Pack stuff, the 3200MHz kit is very flexible, we've ran it at 3866MHz CAS12 in X299, 3600MHz Ryzen and as far as 4500MHz plus in X299 with slacker timings. Stable at all those speeds, not just screenshot.
Are you looking at giving any 2x16 kits the 8 Pack recommendation?
No.
Our 8 Pack ram is not a recommendation it is manufacturered for us to our exact specification, which is only Samsung B die which is only available on 8G modules, hence why they are all 2x8 or 4x8 kits. :)
To go under the 8 Pack branding, it simply has to be the very best!
We are looking for some 4G and 16G modules that fit the bill, but so far nothing has being good enough, as 8 Pack brand is all about performance and premium aesthetics that shout quality, which is why the modules use thick metal heatspreaders that are black in colour.
Excellent, really good to see it get some love as an area you were somewhat lacking before. From what I've seen the pricing is pretty good on it but will certainly take a look at those 8Pack sticks!
Ahh, understood, thanks for the explanation. Didn't realise you actually had them manufactured to requirement, that's pretty nifty ^^
Fingers crossed that someone starts pumping out some quality 16s then :)
neither did i. i just assumed it was certain memory with a slight rebrand on them.
8Pack 4000mhz 2x8 or 4x8 in stock very soon C18. Like Gibbo says I produced the SPD and the binning procedure he produced the rest. The sticks are manufactured for us to our tight spec with special IC and for sure no AWFUL RGB!!!!
Go on pal, throw some Xmas lights on there you know you want to ;)
