OCUK Silentmaxx enclosure
6 Nov 2004
Hi I've got one, another one coming, just a wee question, what does the little cable at the side do? that you connect the front screw to the side screw.
It equalises the Potential difference (PD) from your case to the enclosure. This protects your drive from static, etc.
Matt
Yup, I have the same thing on the Zalman version, it replaces the continuity lost due to the rubber mounts:
