I purchased an OcUK Gaming Radiance Dawn system in April 2023, and it has been as reliable as one can expect of a Windows system - until recently.
I mostly use the system for AI Art with some light gaming. The AI Art makes heavy use of the GPU, and the UI runs in a web browser (I have used MS Edge for this, as I found it more reliable than Google Chrome) under Python, and Python started to crash regularly (hourly) with Event ID 1000, and sometimes I would see an error 0xC0000005 in the logs too. There would also be the occasional BSOD, and event logs would have the less than useful reason of BUGCHECK (sorry, I don't recall the IDs).
I would also get Event ID 1000 fails running games under Renpy.
Running DISM and SFC to check system integrity never revealed an issue.
Yesterday the problems became really bad, with even MS Edge failing with Event ID 1000 / Error 0xC0000005 continually. Having had enough of the issues, I decided to wipe the system drive and re-install Windows 11, so I downloaded the media creation tool to make a bootable USB stick with the OS on it, but when I ran the utility it would quit after a few minutes, and the Event log showed it failing with Error 0xC0000005.
I therefore used a different computer to create the USB stick.
I am now at a loss as to how to proceed, and suspect I may have a hardware issue (the changing fail point during 'identical' install attempts suggested this). My initial thought was maybe the NVME storage or controller had issues, but I have seen threads listing similar symptoms on Reddit where the underlying cause turned out to be a bad CPU.
It is quite a high-end build, so I do not have any components that I can swap-in to do hardware checks.
Can OcUK suggest what I should try next, or is this a case of needing a return so that OcUK can check it out?
Thanks.
- The next step was to configure the machine to boot from USB in the bios and restart.
- Windows installer ran from the USB stick and I told it to format the system disk and install the os
- The 'Installing Windows' dialog appeared, and it copied Windows files (to the system disk)
- It started the second step - Getting files ready for installation - but after a few percent failed with an Unexpected Error - unbelievably it proudly declared Error code: 0xC0000005
Thanks.
