Hi Guys
Following the launch of the new generation of GPU technology from AMD and Nvidia. OcUK Tech Lab is pleased to announce a brand new range of custom graphics solutions.
These graphics cards feature the best cards on the market for overclocking and have been carefully chosen after extensive research and development.
Each Tech Lab H2O card is designed with performance in mind.
All cards feature the following:
Where available, all cards are fitted with a backplate for which provides a cleaner aesthetic to your watercooled card.
GTX 680 backplates will be arriving soon but have not been officially announced yet. They will be added to the 680 lines when they become available.
** Please note, official images of the 680 and 7950 waterblocks are not available currently. The images will be updated to high res images as soon as EK release them **
Take a look at our full range here
OcUK Tech Lab H2O GTX 680 2048MB GDDR5 Nickel Acetal [N680GTX-PM2D2GD5] @ £519.98 inc VAT
The OcUK Tech Lab H2O GTX 680 combines the fastest single GPU card on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the Excellent MSI GeForce GTX 680 2048MB, the OcUK Tech Lab H2O GTX 680 allows for incredible overclocking potential on an already outstanding graphics card.
This graphics card has been updated to include the incredible EK GTX 680 Full Cover Waterblock. This block features a totally new design that optimises thermal performance and maximises overclocking potential.
All of this cooling power would be wasted without the addition of the worlds leading cooling paste, a retail tube of Arctic Cooling MX-4 Thermal Compound (4g) is included with this package. The paste is applied to the GPU to maintain supreme performance with the GPU block.
The remainder of the paste will be sent with the card for future applications.
Note - The waterblock fitted to this card will be EN Nickel Acetal.
- Core Clock: 1006MHz (GK104)
- Core Boost Clock: 1058MHz
- Innovative thermal design: Vapour Chamber (Quieter & Cooler than previous generation)
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2012MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 195 watts at stock speed)
- Card Dimensions: 270*111.15*38.75 mm
- Warranty: 3 Years
Only £519.98 inc VAT.
ORDER NOW
OcUK Tech Lab H2O GTX 680 2048MB GDDR5 Nickel Plexi [N680GTX-PM2D2GD5] @ £519.98 inc VAT
Note - The waterblock fitted to this card will be EN Nickel Plexi.
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
OcUK Tech Lab H2O HD 7950 3072MB GDDR5 Nickel Acetal & Backplate [R7950 Twin Frozr 3GD5/OC] @ £479.98 inc VAT
The OcUK Extreme H2O Radeon HD 7950 combines a blisteringly fast and efficient single GPU card with the most effective cooling solution available. With features such as cinematic DirectX 11 graphics, AMD's Eyefinity Technology and all solid capacitors. .You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the Excellent MSI Radeon HD 7950 OC graphics card, the OcUK Extreme H2O Radeon HD 7950 allows for incredible overclocking potential on an already outstanding graphics card.
This graphics card has been updated to include the incredible EK HD 7950 Full Cover Waterblock. This block features a new revised design that optimises thermal performance and is amongst the greatest blocks that EK have ever produced.
The Graphics card also includes the stunning EK 7950 Backplate for a sleek aesthetic within your system.
Never has a pre built watercooled card been such a complete package!
Cooling: EK HD7950 Block & Backplate
Memory: 3072MB GDDR5
Memory Clock: 5000MHz (effective)
Memory Interface: 384-Bit
Shaders: 1792
Bus Type: PCI-Express 3.0
Display Connectors: 2x Mini DisplayPort, HDMI, DVI-I
Crossfire: Up to 4 Way Support
HDCP: Yes
DirectX 11: Yes
Open GL 4.2: Yes
Eyefinity: Yes
Powerplay: Yes
AVIVO HD: Yes
Warranty: 3 Years
Only £479.98 inc VAT.
ORDER NOW
OcUK Tech Lab H2O HD 7950 3072MB GDDR5 Nickel Plexi & Backplate [R7950 Twin Frozr 3GD5/OC] @ £479.98 inc VAT
Featuring the Excellent MSI Radeon HD 7950 OC graphics card, the OcUK Extreme H2O Radeon HD 7950 allows for incredible overclocking potential on an already outstanding graphics card. The card comes pre-overclocked out of the box but the potential is raised even further with extreme water cooling.
Shaders: 1792
HDCP: Yes
DirectX 11: Yes
Open GL 4.2: Yes
Eyefinity: Yes
Powerplay: Yes
AVIVO HD: Yes
Warranty: 3 Years
ORDER NOW
OcUK Tech Lab H2O HD 7970 3072MB GDDR5 Nickel Acetal & Backplate [R7970-2PMD3GD5/OC] @ £569.98 inc VAT
The OcUK Extreme H2O Radeon HD 7970 combines the one of the fastest single GPU cards on the planet with the most effective cooling solution. With features such as cinematic DirectX 11 graphics, AMD's Eyefinity Technology and all solid capacitors. .You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the Excellent MSI Radeon HD 7970 graphics card, the OcUK Extreme H2O Radeon HD 7970 allows for incredible overclocking potential on an already outstanding graphics card.
This graphics card has been updated to include the incredible EK HD 7970 Full Cover Waterblock. This block features a new revised design that optimises thermal performance and is claimed to be the greatest block that EK have ever produced.
The Graphics card also includes the stunning EK 7970 Backplate for a sleek aesthetic within your system.
Features:-
• EK HD 7970 Nickel Acetal Block, 'The best performing GPU block that EK have ever created'
• EK-FC7970 Backplate - Black, sleek aluminum backplate for striking aesthetics.
• Fastest single GPU graphics card on the planet
• Hugely overclockable
• Vastly cooler running than previous generation
• Quieter running than previous generation
• Compute Power: 3.5 TFLOPS
• Core Clock Speed: 1010MHz
• Primitive Rate: 2 prim / clk
• Shader Architecture: GCN
• Stream Processors: 32 CU / 2048 ALU
• Texture Units: 128
• ROPS / Z-Stencil: 32 / 128
• Frame Buffer / Memory: 3GB GDDR5
• Memory Width / Speed: 384 bit / 5500MHz
• Load / Idle Board Power: <300W / <3W
• Power Connectors: 8-pin + 6-pin
• Display Outputs: 1xDVI + 2x mDP + 1x HDMI
• 3yr Warranty
Only £569.98 inc VAT.
ORDER NOW
OcUK Tech Lab H2O HD 7970 3072MB GDDR5 Nickel Plexi & Backplate [R7970-2PMD3GD5/OC] @ £569.98 inc VAT
Featuring the Excellent MSI Radeon HD 7970 graphics card, the OcUK Extreme H2O Radeon HD 7970 allows for incredible overclocking potential on an already outstanding graphics card. The card comes pre-overclocked out of the box but the potential is raised even further with extreme water cooling.
Features:-
• Core Clock Speed: 925MHz
• 3yr Warranty
ORDER NOW
- A quality EKWB Waterblock with EN Nickel Plated Copper and a choice of tops
- Where available, a pre-overclocked card has been used.
- Assembly by a Technical Expert
- Pre-shipping quality control procedures to ensure that your card is functioning correctly.
- Stress testing to guarantee the best performance.
- MX-4 Thermal Paste for optimal heat transfer
- Each card is built to order, with a lead time that allows us to assemble and test your card to exacting standards.
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
Shaders: 1792
HDCP: Yes
DirectX 11: Yes
Open GL 4.2: Yes
Eyefinity: Yes
Powerplay: Yes
AVIVO HD: Yes
Warranty: 3 Years
ORDER NOW
Shaders: 1792
HDCP: Yes
DirectX 11: Yes
Open GL 4.2: Yes
Eyefinity: Yes
Powerplay: Yes
AVIVO HD: Yes
Warranty: 3 Years
ORDER NOW
Features:-
• 3yr Warranty
ORDER NOW
Features:-
• 3yr Warranty
ORDER NOW
