OcUK Tech Lab - "Ultima 9750i Blade"
27 Sep 2009
Are there any reviews for this or does anyone own one? Like what are the temp specs, 3D mark specs etc. Where are the radiators fitted and what is the sequence of flow?
The pictures show a 360mm Rad at the top of the case, a 120mm on the back and a 240mm rad under the partition.
The Pump is mounted next to the motherboard near the 24 pin connector.
As for performance, this review is for a 7970 with a simular system, just not watercooled. So yours should be able to overclock further.
http://forums.overclockers.co.uk/showthread.php?p=24144302#post24144302
