** OCUK TECH LAB - V POWER IN YOUR SYSTEM **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
We are proud to announce a new addition to our Watercooling Kits from OcUK Tech Lab.
The V10 Kit bridges the gap between the Performance V8 and the Expert V12 kit.
This new V10 kit gives users a smaller watercooling footprint making watercooling your computer easier even in the tightest of cases.
To differentiate our Tech Labs products, we have incorporated a graphic in each listing which designates the target of each kit. This new listing style will make it easier for everyone to decide which kit fulfils their requirements the best.
OcUK Tech Lab - V10 Watercooling Kit 360 @ £234.98 inc VAT
Designed with a small footprint in mind, the components in this kit maximising cooling capacity
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
OcUK have stepped in and solved this problem. With each OcUK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike.
Component List:
1X XSPC EX360 120mm Radiator - Black
Offering superb performance, build quality and value the XSPC EX range of radiators are the obvious choice for high end watercooled systems.
1X Laing 10W DDC-Pump 12V DDC-1T
The best small footprint watercooling Pump on the planet.
1X XSPC Acrylic Tank Reservoir for Laing DDC
A Reservoir that fits on the top of the DDC pump with proven performance.
1X EK Supreme HF CPU Waterblock - Copper Plexi
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supreme' for a reason!
3X Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin Fans
The most recognised performance fans for watercooling radiators.
1X Mayhems Ultra Pure H20 Watercooling Fluid
The purest water available - ensuring the best temperatures.
2X XSPC 7/16" ID [16/11mm] Clear
High quality watercooling tubing with a superb bend radius
2X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Black Nickel Finish
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
IMPORTANT:
Kit is easy to install, use and maintain (thorough installation manual is available on our forums).
This kit can also be upgraded with an additional VGA waterblock!
You will need to buy two additional fittings alongside your graphics card block.
Please ask our friendly sales team for VGA block advice.
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Only £234.98 inc VAT.
ORDER NOW
