** OcUK Tech Labs 780 Ti - Pre Order Now! **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
available to pre order now, the 780Ti in OcUK Tech Labs guise.
We build it, test it, warranty it and support you on it.
This card is mental quick and with a watercooling solution from XSPC, it means it is even more viciously overclockable!!!
We are expecting the blocks any time now so be sure to place your order quickly!
OcUK Tech Labs H2O Custom GTX 780 Ti 3072MB GDDR5 Watercooled Graphics Card @ £674.99 inc VAT
The OcUK Tech Lab H2O GTX 780 Ti combines the fastest single GPU card on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
NVIDIA's latest Geforce 780Ti takes the fight right to the competition in the battle for current worlds fastest single GPU. Packing a fully enabled GK110 GPU with a whopping 2880 cuda cores this card has huge amounts of processing power to enable it to power through any game. Infact the 780 Ti is so impressive, it’s not just cheaper than TITAN, it beats it in performance and takes the crown as the Best Gaming GPU on the Planet.
Specification
GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 876MHz
- Core Boost Clock: 928MHz
- Memory Clock: 7000MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Only £674.99 inc VAT.
ORDER NOW
