Hi Guys
Today I have slashed the prices of the Asetek based OcUK Tech Labs Cooling upgrade bundles and made some changes to make them even more attractive.
They now all come with a full size tube of Thermal Grizzly Hydronaut Thermal Paste as well as the OcUK Exclusive FQ121WC Fan.
The price drops are significant putting them in prime position to be the best performance/value AIO solutions available right now.
OcUK Tech Labs 120mm Extreme CPU Liquid Cooling Upgrade Bundle @ £55.88 inc VAT
Tame your CPU with the OcUK Tech Labs Extreme All In One CPU Liquid Cooling bundle
The entry level 120mm cooler is ideal for small space constraints or low heat output processors. The 240mm+ coolers are designed for more extreme applications and are ideal for cooling and overclocking high performance processors.
Paired with OcUK designed, watercooling radiator optimised fans, the Tech Labs All In One CPU Liquid Coolers provide superb value for money as well as incredible performance.
The AIO Liquid coolers in these system integration solutions are manufactured by industry leader; Asetek.
We ship every bundle with a tube of high performance Thermal Grizzly Hydronaut High Performance Thermal Paste - 1.5ml / 3.9g. This is the ideal thermal paste for ultimate performance with your upgrade.
Every Bundle has an option to include an OcUK Tech Labs recommended Fan Control unit that will ensure that you get the very best out of your Cooling Upgrade Bundle
Each CPU cooler is unbranded with a smart, stealth appearance. No flashing LEDs, no corporate logos or garish branding.
Installation is easy and all mounting hardware and instructions are included. Please ensure that your chassis is capable of accommodating the size of radiator you choose.
Cooler Features:
- Heat Exchanger Size: 120x120x49 mm
- Gen 4 Integrated Pump and Copper Cold Plate
- Double Thick 120mm Aluminum Heat Exchanger
- Designed for Single Fan Operation
- Factory Filled and Sealed, No Refilling Needed
- High Flexibility, Low Permeability Tubing
- 2 Year Warranty
Included in this bundle:
- Premium CPU Mounting Hardware
- Thermal Grizzly Hydronaut High Performance Thermal Paste - 1.5ml / 3.9g
- Asetek 120mm 570LC High Performance Compact AIO Liquid Cooling Solution
- OcUK FQ121WC Watercooling Radiator Fan
Was £66.73 Inc. VAT
Only £55.88 inc VAT.
ORDER NOW
OcUK Tech Labs 240mm Extreme CPU Liquid Cooling Upgrade Bundle @ £59.83 inc VAT
Cooler Features:
- Heat Exchanger Size: 120x120x30 mm
- 2400mm Aluminum Heat Exchanger
- Designed for Dual Fan Operation
- Requires 2 adjacent 120mm fan ports
- 2 Year Warranty
- Asetek 240mm 570LXL High Performance Compact AIO Liquid Cooling Solution
- 2X OcUK FQ121WC Watercooling Radiator Fan
Was £74.99 Inc. VAT
Only £59.83 inc VAT.
ORDER NOW
OcUK Tech Labs 240mm+ Extreme CPU Liquid Cooling Upgrade Bundle @ £62.83 inc VAT
Cooler Features:
- Heat Exchanger Size: 240x120x38 mm
- Double Long, Extra Thick 120mm Aluminum Radiator
- 2 Year Warranty
- Asetek 240mm 570LX High Performance Compact AIO Liquid Cooling Solution
Was £79.94 Inc. VAT
Only £62.83 inc VAT.
ORDER NOW
OcUK Tech Labs 360mm Extreme CPU Liquid Cooling Upgrade Bundle @ £92.78 inc VAT
Cooler Features:
- Heat Exchanger Size: 360x120x30 mm
- Thick 360mm Aluminum Heat Exchanger
- Designed for Triple Fan Operation
- 2 Year Warranty
- Asetek 360mm 591LX High Performance Extreme AIO Liquid Cooling Solution
- 3X OcUK FQ121WC Watercooling Radiator Fan
Was £109.94 Inc. VAT
Only £92.78 inc VAT.
ORDER NOW
Cooler Features:
- 2 Year Warranty
Was £66.73 Inc. VAT
ORDER NOW
Cooler Features:
- 2 Year Warranty
Was £74.99 Inc. VAT
ORDER NOW
Cooler Features:
- 2 Year Warranty
Was £79.94 Inc. VAT
ORDER NOW
Cooler Features:
- 2 Year Warranty
ORDER NOW
