** OcUK Tech Labs - BATTLE OF THE TITANS **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
They aren't quite titans, but these capable cards are TITAN beaters.
Plain and simple, the most overclockable VGA on the planet right now from EVGA and MSI
the blocks are on order and should be here soon. Order now to secure your expertly hand assembled card.
OcUK Tech Lab H2O Custom MSI GeForce GTX 780 Lightning 3072MB Watercooled Graphics Card @ £619.99 inc VAT
The OcUK Tech Lab H2O GTX 780 Lightning combines the fastest single 780 GPU cards on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the Excellent MSI GeForce GTX 780 Lightning, the OcUK Tech Lab H2O GTX 780 allows for incredible overclocking potential on an already outstanding graphics card.
This graphics card comes complete with your own choice of VGA block from industry leading manufacturers.
Choose the block that suits your own taste for a truly customised feel inside your system.
Never has a pre built watercooled card been such a complete package!
Features:
- 16+3+1 (20) Phase Power
- Propeller Blade Technology
- 8 SuperPipes and dense aluminium fins to maximize thermal dissipation
- LN2 Mode
- Triple level signals show the real-time load with different colours
- TriFrozr Thermal Design - Three PWM fans with independent control on the most advanced thermal design.
- Pure digital PWM Control - Digital GPU / Memory / AUX voltages
- Twin BIOS
- Enhanced Power - 16 GPU phases and 3 memory Phases on a custom designed 10 layers PCB for amazing overclocking potential.
- GPU Reactor for improved OC ability providing 300% higher power capacity and reduces power noise (ripple)
- MIL-STD-810G standard certified to ensure the best stability and quality.
- Uses DrMOS 4, CopperMOS, Hi-c CAP, new SFC and Dark Solid CAP.
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 980 MHz
- Core Boost Clock: 1033 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- Warranty: 3yr
Only £619.99 inc VAT.
ORDER NOW
OcUK Tech Labs H2O Custom EVGA GeForce GTX 780 Classified "Dual BIOS" 3072MB Watercooled Graphics Card with Backplate @ £609.98 inc VAT
Classified means Overclocking Domination
The OcUK Tech Lab H2O GTX 780 Classified combines the fastest single 780 GPU cards on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the Excellent GTX 780 Classified, the OcUK Tech Lab H2O GTX 780 allows for incredible overclocking potential on an already outstanding graphics card.
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- Dual BIOS
- Core Base Clock: 993 MHz
- Core Boost Clock: 1046 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Only £609.98 inc VAT.
ORDER NOW
Excellent idea... AWESOME!
Also good to see that the Lightnings are reference PCB, because with the 580 Lightnings they were none ref meaning that water cooling isn't really an option for me unless gpu only block.
Lightning are a custom PCB. This is a custom block specifically for the overclockable lightning card.
Classified blocks landed yesterday meaning we can build the cards straight away for you guys.
I love getting stuff wrong and learning new things :) haha :)
