Hi Guys
From today, our triple pack bundle for the OcUK Tech Labs FQ121WC fan is changing.
We are now offering the triple pack for £15.95 - Just over £5 per fan making the FQ121WC easily one of the most affordable options for people looking for performance on a budget.
Three Fan Bundle - Overclockers UK & SilverStone - 120mm FQ121WC Watercooling Radiator Fan @ £15.95 inc VAT
Watercooling enthusiasts have typically been left with slim choices when picking a suitable fan for their projects. Specialist cooling fans developed for Liquid Cooling tend to have a significant price tag associated with them and make adding multiple fans to large projects being
The FQ121WC fan from SilverStone sets a brilliant baseline for Liquid Cooling performance featuring high quality components and impressive specifications at a great price point. We have worked with Silverstone to produce a more focussed product that is entirely aimed at Watercooling, Performance and Hardware Enthusiasts that doesn't break the bank.
Not only is the FQ121WC perfect for bespoke liquid cooled system projects, but it makes a worthy upgrade for AIO Liquid Cooler users.
A number of small but significant changes were made to the product to refine it and make it a real prospect for people looking for exceptional performance at a wallet friendly price.
The FQ121WC is completely black with minimal stickers and branding to ensure that hardware modders have a great base for painting and customisation. The fan blades can be easily removed from the fan motor and the blades are made from the same high quality PBT plastic that the FQ121 fan it derives from. This ensures a solid and premium product feel as well as being hardwearing and durable.
The PWM feature from the original fan has been removed in favour of a 3 pin connector. This change was made to be compatible with fan control units and smart controllers such as the Aqua Computer Aquaero. This fan is designed to be used with fan controllers to give you the best performance and speed/noise output.
The Cable of the FQ121WC is flat to ensure that cable management is easy and that cables can be layered on top of each other in tight spaces when the fans are placed next to eachother on watercooling radiators.
The cable and connector are both black to ensure a stealth and uniform appearance.
Features:
- Custom design meeting the needs of Hardware and Liquid Cooling enthusiasts
- Optimum airflow, pressure and extremely silent performance
- Specified for Watercooling application
- Innovative blade design focuses airflow with maximum efficiency
- Air-inlet with optimized aerodynamic design reduces noisy air turbulence
Specifications:-
- Model No. FQ121WC
- Material P.B.T.
- Color Black blade/black frame
- Bearing P.C.F. bearing (Powder Copper Fluid Bearing)
- Rated Voltage 12V
- Start Voltage =7V
- Speed: up to 1,800rpm
- Airflow 67.5CFM (at maximum speed)
- Static Pressure 0.54 – 1.82mmH2O
- Noise Level 16.4 – 24 dBA
- Life Time 150,000 hours
- Weight 143±5g
- Dimension 120mm (L) x 120mm (W) x 25mm (D)
Was £20.99 Inc. VAT
Only £15.95 inc VAT.
ORDER NOW
Features:
Specifications:-
- Model No. FQ121WC
- Material P.B.T.
- Rated Voltage 12V
- Start Voltage =7V
- Weight 143±5g
Was £20.99 Inc. VAT
ORDER NOW
