** OcUK Tech Labs Fathom All in One Custom Cooler **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Bit of a project from me here, myself and 8Pack have worked on these for a long time now to get something we were both happy with. It has paid off and we are able to offer our fantastic new coolers under the Tech Labs brand.
The Fathom cooler is essentially a pre filled Eisberg Solo cooler that comes with customisable, performance fans and uses attractive coolants.
8Pack has been testing this cooler on some really mental stuff including 5GHz AMD processors and the results have been brilliant.
Gallery:
Performance Results:
Fathom 240 - 5GHz @ 70'C using the 7v adapter on the pump
OcUK Tech Labs Fathom All in One Custom Cooler 120mm @ £139.95 inc VAT
All in One Liquid cooling solutions are ten a penny in the enthusiast market these days. Every brand has an option and many hard core enthusiasts are aware that a high performance air cooler generally provides better performance characteristics than most all in one solutions.
Following on from months of development work and intensive testing on the most demanding hardware, we are finally ready to offer the ultimate all in one solution.
Each OcUK Tech Labs Fathom All in One Custom Cooler is hand assembled by expert technicians and pre filled for your convenience. The Fathom cooler is designed to be an out of box product that provides unmatched cooling performance and custom aesthetics without the hassle of a full watercooling solution.
We fill, leak test and quality control each Fathom unit in house at OcUK. This means that you are guaranteed a cooler that has been assessed and certified by an expert before it arrives with you.
The Fathom cooler also offers coolant options in a vast variety of colours giving you the opportunity to create a truly unique cooler.
Socket Compatibility:
- LGA 2011 / 1366 / 1156 / 1155 / 1150 / 775
- FM1 / AM3+ / AM3 / AM2+ / AM2
Specification:
- Cooler Master Eisberg Solo Prestige Water Block.
This unique block/pump/reservoir combo allows for easy refilling and offers excellent cooling and comes with thermal paste.
- XSPC 7/16 Compression fittings, Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
- XSPC Clear Tubing
Show off your liquid colour in your system
- A choice of Standard or Advanced radiator options that cater for different case sizes and performance requirements
- Mayhems Coolant offers an excellent palette of colour options in both clear and pastel.
- Corsair SP120 Quiet Series High Pressure Low Noise 1450 RPM - 3 Pin Fan, Market leader for static pressure on watercooling radiators. Features interchangeable accent rings to customise the appearance of your system
* We suggest using the included reducer cable with your Fathom cooler to fine tune the balance between pump speed and noise output. Our research shows that 7v is useful for 120mm applications but 12v is suited for the 240mm radiator option.
* Each Fathom cooling system arrives pre filled but you may find that it requires topping up as the air in the system can move around in transit. We send spare coolant to you with your order so that you can do this before installation.
From £139.95 inc VAT.
ORDER NOW
OcUK Tech Labs Fathom All in One Custom Cooler 240mm From £159.95 inc VAT
Specification:
- XSPC Clear Tubing
From £159.95 inc VAT.
ORDER NOW
Cool idea but that price :/ Not sure if it can go against XSPC kits :(
Benchmarks VS corsair ones please :)
In addition to benchmarks, it would be good to know what the warranty is on these; how long, and is any damage due to leaks covered?
