Its my last day at OcUK
Here is a project I have been working on for a long time.
Super High Performance.
OcUK Tech Labs High Performance Watercooling Cleanup Towel @ £499.99 inc VAT
Any Hardware Enthusiast knows the struggle, Hardcore cooling solutions require hardcore clean-up devices. The OcUK Tech Labs High Performance Water Cooling Cleanup Towel has you covered.
As hardware develops, the requirement for a heavy duty cleanup device increases. High Performance computer hardware requires precision installation but accidents do happen and hardware failures can be catastrophic.
Our super soft OcUK Tech Labs High Performance Water Cooling Cleanup Towel is ultra-absorbent offering exceptional levels of moisture wicking. Perfect for cleaning up spills caused by poor installation techniques or sub-elite tier hardware use.
Using quality Egyptian Cotton, the OcUK Tech Labs High Performance Water Cooling Cleanup Towel is fit for use by the Pharos of system building. Make a statement with this stylish and practical rectangular design.
Features:
- Double stitched edges to avoid fraying when scrubbing CPU sockets
- Suitable for Bath Time cleanup tasks
- Cosy Feel with patented soft touch technology allows for smooth operation within PC Cases.
- Easy Care Machine Washable
- Compatible with a wide range of specialist watercooling fluids
- Fully Stain and Dye resistant
- Attractive OcUK Logo to remind you where to buy your replacement hardware
- Compatible with watercooling, heatsinks, fans, cooling, Gaming PCs and a host of other SEO optimised words.
Specification:
- High Density Egyptian Cotton fibre construction
- Capacity: 1.5litres of Watercooling Fluid or Salty Tears
- Colour: Black
- Size: 70x120cm
Warning:
Not Liquid Nitrogen Compatible
Keep Away from Fire
Only £499.99 inc VAT.
ORDER NOW
CHECK OUT THE WATERCOOLING RANGE AT OCUK NOW
Features:
Specification:
- Colour: Black
- Size: 70x120cm
Warning:
Keep Away from Fire
ORDER NOW
