** OCUK TECH LABS KIT UPDATES **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Over the past few days I have been working on a nice update for our OcUK Tech Labs Watercooling Kits to make them better value for money, better performers and offer improved products within them.
From today onwards we are offering the following:
Radiator Updates:
All Tech Labs WC Kits will come with a choice of our fantastic Hardware Labs Black Ice Radiators. Ranging from the great value GTS Lite all the way to the new Nemesis GTX series.
These are labelled clearly on the dropdown with Standard, Advanced, Premium and Ultimate options to indicate the performance they would offer.
Fan Updates:
Our technical department and 8Pack have been using the Noiseblocker NB-eLoop Fan B12-2 (120mm/1300rpm) in all of 8Pack's systems recently and the performance has blown us away. We do suggest to pair these fans with a fan controller and run them slower for best results but the fan is a perfect match for the Black Ice Radiator range we are offering in our kits regardless of the speed you run it at. Each kit comes with the exact amount of fans you need.
Tubing Update
No cheap tubing here, all OcUK Tech Labs Kits now ship with a length of Primochill Primoflex LRT tubing. This stuff is superb and clear as glass. It also has no nasty plasticiser in it meaning there is zero chance of your loop getting gunked up with rubbish and your system will look awesome all the time!
Tubing Colour Drop Down
Now we offer a range of colours with the default being clear, coloured tubing is available on all of our kits. We would like to offer 2 meters of tubing but having the drop down means we can only offer one meter of tubing. tubing can also be purchased on our shop in additional lengths if required but one meter should be fine for a simple loop.
Pump & Reservoir Combo Options
A bunch of people asked me, so we included it also. The 120 and 240 kits originally just came with the basic XSPC 750 reservoir combo and whilst it is a decent starter product, some people wanted more extravagant solutions. I have included the D5 bay reservoir as a step up and also the photon combos for people who want an internal tube reservoir solution.
The product description has been updated to reflect that you will need to ensure your case fits the tube res also.
The rest of the offerings are pretty much the same as what wasn't broken, we didnt fix.
The other thing we did change drastically was the discount we offer.
Each kit comes with a huge saving now, even bigger than previously.
This is the perfect time to get into WC.
Check out the range below.
OcUK Tech Lab - V6 Watercooling Kit 120
OcUK Tech Lab - V8 Watercooling Kit 240
OcUK Tech Lab - V12 Watercooling Kit 360
OcUK Tech Lab - W16 Watercooling Kit 480
added info about tubing drop down options and pump drop down options.
These updates happened today.
We have managed to drop the pricing a little lower by having a play around with margins too.
all good!
all good!
Very competitive pricing, and the fans were inspired by me ;)
Now very tempted as summer is here and I'm not liking my temps with SLI active, are any of these powerful enough to include 2 GPU's in loop with an extra rad?
