** OcUK Tech Labs Kits - V6, V8, V12, W12 & TURBO! **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
We have a new structure to our Watercooling Kits from Tech Labs.
I have changed the way they are presented so that every customer can find a kit which is perfect for their needs.
The categories are as follows:
V6 - This is an entry level single fan kit offering great performance designed to cool a CPU easily
V8 - A double fan upgrade making for ultimate CPU cooling.
V12 - Our previous flagship kit, this triple fan kit can also easily incorporate a VGA waterblock.
NEW W16 - An ultimate performance kit with four fans, this kit can be paired with one or two VGA blocks.
We have a Turbo option for every Kit meaning that if you prefer a 140mm radiator setup, then that option is now open to you.
Every OcUK Tech Labs Watercooling Kit now offers a Radiator option to suit your budget and requirements:
Standard - A good quality radiator that will work well with your kit.
Premium - A high quality solution that offers more features or performance.
Advanced - The most high performance solution we offer in this category.
Check out the OcUK Tech Labs Kits now:
OcUK Tech Lab - V6 Watercooling Kit 120
ORDER NOW
OcUK Tech Lab - V8 Watercooling Kit 240
ORDER NOW
OcUK Tech Lab - V12 Watercooling Kit 360
ORDER NOW
OcUK Tech Lab - W16 Watercooling Kit 480
ORDER NOW
OcUK Tech Lab - V6 Turbo Watercooling Kit 140
ORDER NOW
OcUK Tech Lab - V8 Turbo Watercooling Kit 280
ORDER NOW
OcUK Tech Lab - V12 Turbo Watercooling Kit 420
ORDER NOW
OcUK Tech Lab - W16 Turbo Watercooling Kit 560
ORDER NOW
Coolio, when will the watercooled case range be reappearing? e.g. the V12 Watercooled 800D etc...
thats very much on my to do list.
at the moment i am concentrating on a whole new section of tech labs, the new watercooled case range will essentially be a sub section of this.
restructuring takes time, plus everything needs to be tested on the website to make sure when you add a radiator on the drop down menu that you dont get sent a tube of arctic silver or a copy of euro truck simulator :p
Lol true, cheers for the info! I'll be getting a watercooled 900D from your watercooled case range anyway so there's no hurry as that will only be available by or after the 7th of June I'd imagine.
Really well thought out kits Rich, excellent for first time watercoolers wanting really great performance.
Typos in OP W16 (not W12) in subject/title and text
Nice, more improvements :D
Kits look great, what other cases (that you stock) support the 560 kit besides the tj11 though?
I like the W12 and W16 idea for the names :D
I remember saying the WC'd 900D should be have W16 watercooling :p
Sounds more like the dispatching system more than the site system.
Some nice W/C kits there, and good to see them with pump/res combos - great use for often redundant 5.25" bays.
Any plans for stocking 180mm radiators? I'm considering W/C for my TJ08E and a 180mm radiator would be perfect for the front AP181 - maybe a Uber Turbo mode which ups it to a 180mm rad ;)
