** OcUK Tech Labs Presents: The Most Crazy AIO GPU Coolers Available **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Today We have launched a new set of VGA cooling solutions featuring exclusive performance options including a 360mm AIO cooler.
Over the next week we will be offering CPU versions of these also
Each of them are available with Red, Black or White shrouds to match your system and I have aimed to make the prices very aggressive when compared to similar products.
Full Range Here
OcUK Tech Labs 120mm Kraken Extreme VGA Cooler - Standard - Black Shroud @ £73.27 inc VAT
Tame your graphics card with the OcUK Tech Labs VGA Liquid Cooler.
Featuring the Kraken performance cooler bracket from NZXT in a range of colours to match your system theme, the Tech Labs VGA cooler is compatible with all major graphics cards and cools the graphics core directly.
The entry level 120mm coolers are ideal for small space constraints or low heat output graphics cards. The 240mm+ coolers are designed for more extreme applications and are ideal for cooling and over clocking on flagship graphics cards.
Paired with OcUK designed, water cooling optimised fans, the Tech Labs VGA Liquid coolers provide superb value for money as well as incredible performance.
The AIO Liquid coolers in these system integration solutions are manufactured by industry leader; Asetek.
Installation is easy and all mounting hardware and instructions are included. Please ensure that your chassis is capable of accommodating the size of radiator you choose.
Cooler Features:
- Heat Exchanger Size: 120x120x49 mm
- Gen 4 Integrated Pump and Copper Cold Plate
- Double Thick 120mm Aluminum Heat Exchanger
- Designed for Single Fan Operation
- Factory Filled and Sealed, No Relling Needed
- High Flexibility, Low Permeability Tubing
Included in this bundle:
- NZXT Kraken G10 GPU Cooling Adapter
- Asetek 120mm 570LC High Performance Compact AIO Liquid Cooling Solution
- OcUK FQ121WC Watercooling Radiator Fan
Only £73.27 inc VAT.
ORDER NOW
OcUK Tech Labs 240mm Kraken Extreme VGA Cooler - Advanced - Black Shroud @ £81.56 inc VAT
Cooler Features:
- Heat Exchanger Size: 120x120x30 mm
- 2400mm Aluminum Heat Exchanger
- Designed for Dual Fan Operation
- Requires 2 adjacent 120mm fan ports
- Asetek 240mm 570LXL High Performance Compact AIO Liquid Cooling Solution
- 2X OcUK FQ121WC Watercooling Radiator Fan
Only £81.56 inc VAT.
ORDER NOW
OcUK Tech Labs 240mm+ Kraken Extreme VGA Cooler - Premium - Black Shroud @ £86.57 inc VAT
Cooler Features:
- Heat Exchanger Size: 240x120x38 mm
- Double Long, Extra Thick 120mm Aluminum Radiator
- Asetek 240mm 570LX High Performance Compact AIO Liquid Cooling Solution
Only £86.57 inc VAT.
ORDER NOW
OcUK Tech Labs 360mm Kraken Extreme VGA Cooler - Ultimate - Black Shroud @ £109.81 inc VAT
Cooler Features:
- Heat Exchanger Size: 360x120x30 mm
- Thick 360mm Aluminum Heat Exchanger
- Designed for Triple Fan Operation
- Asetek 360mm 591LX High Performance Extreme AIO Liquid Cooling Solution
- 3X OcUK FQ121WC Watercooling Radiator Fan
Only £109.81 inc VAT.
ORDER NOW
Look forward to seeing what the CPU ones are like, could be tempted to try a 360mm one if it's better than my h110.
I've just made a post pondering my GPU cooling options, I wonder if this kit would suit me perhaps I could ask a few questions?
Looking at the top 120mm option for £73.27, would this work on a Gigabyte GTX 780 GHz edition? I don't know if it has a reference card layout.
How long are the tubes? I want something that can reach the top of my tank, 18" or so from the bottom card depending if it can come out the side of the card or if it has to run along to the front end of the case then up.
What is the cooling capacity in watts? I need something around 450W each I think.
More details of my specific machine on my post linked above.
