** OcUK Tech Labs Presents: The Most Crazy VGA Cooling Upgrade Bundle Available **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Today We have launched a new set of VGA cooling solutions featuring exclusive performance options including a 360mm AIO cooler.
Over the next week we will be offering CPU versions of these also
Each of them are available with Red, Black or White shrouds to match your system and I have aimed to make the prices very aggressive when compared to similar products.
Full Range Here
OcUK Tech Labs 120mm Kraken Extreme VGA Cooler - Standard - Black Shroud @ £73.27 inc VAT
Tame your graphics card with the OcUK Tech Labs VGA Liquid Cooler.
Featuring the Kraken performance cooler bracket from NZXT in a range of colours to match your system theme, the Tech Labs VGA cooler is compatible with all major graphics cards and cools the graphics core directly.
The entry level 120mm coolers are ideal for small space constraints or low heat output graphics cards. The 240mm+ coolers are designed for more extreme applications and are ideal for cooling and over clocking on flagship graphics cards.
Paired with OcUK designed, water cooling optimised fans, the Tech Labs VGA Liquid coolers provide superb value for money as well as incredible performance.
The AIO Liquid coolers in these system integration solutions are manufactured by industry leader; Asetek.
Installation is easy and all mounting hardware and instructions are included. Please ensure that your chassis is capable of accommodating the size of radiator you choose.
Cooler Features:
- Heat Exchanger Size: 120x120x49 mm
- Gen 4 Integrated Pump and Copper Cold Plate
- Double Thick 120mm Aluminum Heat Exchanger
- Designed for Single Fan Operation
- Factory Filled and Sealed, No Relling Needed
- High Flexibility, Low Permeability Tubing
Included in this bundle:
- NZXT Kraken G10 GPU Cooling Adapter
- Asetek 120mm 570LC High Performance Compact AIO Liquid Cooling Solution
- OcUK FQ121WC Watercooling Radiator Fan
Only £73.27 inc VAT.
ORDER NOW
OcUK Tech Labs 240mm Kraken Extreme VGA Cooler - Advanced - Black Shroud @ £81.56 inc VAT
Cooler Features:
- Heat Exchanger Size: 120x120x30 mm
- 2400mm Aluminum Heat Exchanger
- Designed for Dual Fan Operation
- Requires 2 adjacent 120mm fan ports
- Asetek 240mm 570LXL High Performance Compact AIO Liquid Cooling Solution
- 2X OcUK FQ121WC Watercooling Radiator Fan
Only £81.56 inc VAT.
ORDER NOW
OcUK Tech Labs 240mm+ Kraken Extreme VGA Cooler - Premium - Black Shroud @ £86.57 inc VAT
Cooler Features:
- Heat Exchanger Size: 240x120x38 mm
- Double Long, Extra Thick 120mm Aluminum Radiator
- Asetek 240mm 570LX High Performance Compact AIO Liquid Cooling Solution
Only £86.57 inc VAT.
ORDER NOW
OcUK Tech Labs 360mm Kraken Extreme VGA Cooler - Ultimate - Black Shroud @ £109.81 inc VAT
Cooler Features:
- Heat Exchanger Size: 360x120x30 mm
- Thick 360mm Aluminum Heat Exchanger
- Designed for Triple Fan Operation
- Asetek 360mm 591LX High Performance Extreme AIO Liquid Cooling Solution
- 3X OcUK FQ121WC Watercooling Radiator Fan
Only £109.81 inc VAT.
ORDER NOW
I've been using a similar setup to the 120mm one here for my 7950 and can highly recommend doing it, makes an incredible different to noise and heat on AMD cards :)
Even works well on a 980 to be honest, even with a single 120mm radiator I was seeing load temps sub 50c which was impressive, I imagine the dual or triple would keep load sub 40c which is great for big overclocks and keeping stability. Especially if your trying for 1600MHz on a 980.
Of course on 290 series, they offer a serious improvement in both temperatures and acoustics. :)
I rarely see over 45 degrees on my 7950 which when you consider it use to sit over 85 most evenings is pretty damn good. I'm hoping to move to a newer card later in the year so you guys offering these kits will come in handy :D
Anychance of a bundle/s with an EK thermosphere block,a rad and fans for those of us lookin at add gpu's to existing custom loops?
Could we also get a bit more information on the difference between the 570LXL and the 570LX rads? I can see from the specs that the 570LX is thicker, but are the fins per inch the same? Google isn't very helpful, These don't seam to be sold anywhere.
Thats a dead specific thing to make a bundle for. Just grab the bits you need as I can't see it being useful for loads of people.
They aren't sold anywhere as they are Asetek units for oem use. We use these for our system builds. Asetek are the largest OEM of AIO liquid coolers in the world.
Asetek have full descriptions on their site for the details. Basically the NZXT and old corsair units are/were made by Asetek.
The 360, I can't remember the tube length off the top of my head, however I did request the longer tubes when I ordered. Will see if I can find the info in my email tomorrow
I won't include them but will suggest that customers include them in their basket.
Yeah but you dont sell any for the VRM's anymore !! You used to sell the Alpenföhn Passive DRAM / VRAM Chip Coolers which was perfect for RAM and VRM's.
I also think the NZXT X41 AIO is a better solution with the G10's because of the longer hoses, thicker rad and excellent CAM software letting you control the pump RPM, show temp of liquid, gpu, cpu temp, change colour of logo on pump etc.
Personally I think the double rads are a bit overkill. I was getting 45c max with the X41 on a 980.
We have heatsinks if you want them. You just aren't looking hard enough.
http://www.overclockers.co.uk/produ...d=2330&sortby=manual_sort&subid=787&mfrid=460
The NZXT unit is basically the same as these in terms of pump but it has controllers built in and software with LEDs and lighting. But then it costs loads more money.
I could understand you comparing the units to corsair etc but the NZXT stuff you are championing is made by Asetek.
Will these work with 8gb 290's?
It fits the core only so as long as the core is the same as a regular 290 then I can't see why not.
As mentioned though, I would suggest some additional heatsinks if you are planning on over clocking
