Hi Guys
We have some fantastic deals on our new Prolimatech Cooling bundles. Based on the award winning and unique Genesis cooler, these bundles include vortex boosters to increase static pressure over the heatsink. The fans an vortex boosters work in perfect harmony to create a perfect cooling solution.
This is ideal for people looking for a no compromise cooling solution.
Plus, with each bundle you are saving £25 off the RRP of all items.
Bargain deals.
Our custom cooler section is in the middle of a total overhaul over the next few days and will be updated with new pricing and more mega discounts like this!
OcUK Tech Labs Custom Coolers
OcUK Tech Labs - Prolimatech Genesis "Dual Boosted Static UPS PWM Edition" @ £74.99 inc VAT
OcUK Tech Labs Cooling Bundles are designed to offer proven performance. Each bundle is hand-picked to fulfil a specific role. If you want performance, silence, small form factor or aesthetics there is an OcUK Tech Labs Cooling Bundle for you. Buying an OcUK Tech Labs Cooling Bundle also offers a significant saving over buying individual parts separately.
A stunning combo, Prolimatech static pressure boosters work brilliantly with the Genesis cooler to create an incredibly potent cooling solution.
Prolimatech Genesis Mega Performing CPU Cooler
Tower CPU heatsinks have been mainstream for the past few years. While power end users may consider them to be pinnacle when it comes to performance, there are others who would prefer down draft low profile heatsinks for their versatile ability to cool not just the CPU but also its surrounding components such as RAM, MOSFET, and Northbridge chipset heatsink. Genesis combines the best of both worlds with top-notch engineering design and superior built quality and performance that are surpassed by none. Either 120mm or 140mm can be installed on the Genesis for a maximum installation of 3 fans of your choice! If you are looking to overclock your CPU to the max while keeping your system stable, we highly recommend the ultimate CPU heatsink, Genesis. The New Era of Super Cooler has arrived.
- High clearance for better motherboard compatibility
- Massive cooling range; cools not only CPU but also MOSFET and RAM
- Cooler surrounding temperature allowing more stable environment for higher overclock
- Takes both 12 and 14cm fans for a maximum installation of 3 fans
- Six high quality heatpipes for effective heat transfer
- Light weight at 800 grams (without fans) in the highend class
- Intel and AMD platform supported. All mounting hardwares are included
- Suggested Fans: 800-1600 RPM
- 6 x 6mm heatpipes
Prolimatech Ultra Sleek Vortex Fan - 140mm
Thick, bulging, protruding, and crowding your case, those are the other guy's fans. But Prolimatech looks to give you your space back! No thicker than a stack of 11 pennies, the Ultra Sleek Vortex Fan is only 15 mm thick! With 17 blades and variable fan speeds of 500 to 1000 RPM, this sleek machine offers superb high static pressure and wind volume while hardly making a noise!
Dimension: (L)140mm X (W)140mm X (H)15mm (with 120mm mounting holes)
Bearing: Double Ball Bearing
Net Weight: 91g
Fan Speed: 500 ~ 1000 RPM (±100RPM)
Noise Level: 9 ~ 18 dBA
Airflow: 98 CFM
Connector: 4 PIN PWM
Rated Voltage: 12 V
Rated Current: 0.19 Max. Amp
Input Power: 2.04 W
Input Current: 0.19 Max. Amp
MTBF: 100,000 h / 35? or 60,000 h / 60?
Static Pressure: 0.9 mm H2O (at 1,000 RPM)
Bundle Contents
CPU cooler: Prolimatech Genesis CPU Cooler
Fan: 2x Prolimatech Ultra Sleek Vortex - 140mm fan
Add-On: Prolimatech Static booster for Ultra Sleek Vortex 140mm - black
Y-cable: Akasa PWM Y-cable sleeving - 15cm
Was £102.94Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
OcUK Tech Labs - Prolimatech Genesis Black Series "Dual Boosted Static UPS PWM Edition" @ £79.99 inc VAT
Prolimatech Black Genesis Mega Performing CPU Cooler
- 6 x 6mm heatpipes
- Stylish Black finish.
Net Weight: 91g
Airflow: 98 CFM
Rated Voltage: 12 V
Input Power: 2.04 W
Bundle Contents
CPU cooler: Prolimatech Black Genesis CPU Cooler
Was £104.94 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Bargain deals.
- 6 x 6mm heatpipes
Net Weight: 91g
Airflow: 98 CFM
Rated Voltage: 12 V
Input Power: 2.04 W
Bundle Contents
Was £102.94Inc. VAT
ORDER NOW
- 6 x 6mm heatpipes
Net Weight: 91g
Airflow: 98 CFM
Rated Voltage: 12 V
Input Power: 2.04 W
Bundle Contents
ORDER NOW
