Hi Guys
Blocks are live for the Titan X
HERE
We also have a pre order live for Titan X Tech Labs Cards.
OcUK Tech Labs H2O Custom GeForce Titan X 12288MB GDDR5 PCI-Express Graphics Card - EKWB Edition From £1,099.99 inc VAT
The OcUK Tech Lab H2O Custom GeForce Titan X combines the fastest single GPU card available with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
With a choice of the finest cooling solutions from EK Water Blocks, this card looks incredible no matter what finish you choose.
Never has a pre built watercooled card been such a complete package!
All of this cooling power would be wasted without the addition of the worlds leading cooling paste, a retail tube of IC Diamond is included with this package. The paste is applied to the GPU to maintain supreme performance with the GPU block.
TITAN X takes today’s most demanding games and scenarios in its stride, and at the recent Game Developers Conference (GDC) the world saw its full range of capabilities in next-gen experiences, too. Of those experiences, Virtual Reality (VR) is poised to be the next-big thing. Why? Because you’re immersed in the game in a way that was previously impossible. It’s you, directly in the game, with a real stereoscopic viewpoint, often with physical extensions of your body rendered on-screen when exploring and interacting with objects. It’s nigh on impossible to effectively describe, but once you try it you’ll be taken aback, gawping with wonder and grinning like a Cheshire cat. It truly is the future of gaming.
Unsurprisingly then, wherever you went at GDC jaws were dropping left and right thanks to the many VR demos, and powering the graphically advanced showcases from leading developers such as Crytek and Epic was TITAN X. Each demo was rendered on a VR headset with two high-resolution displays running at 90Hz, requiring a constant 90 frames per second, per screen, and TITAN X was the only GPU in town up to the task.
TITAN X’s performance makes it equally adept at running next-gen experiences, like Epic Games’ Unreal Engine 4 Kite demo that demonstrates the fidelity possible in future games. Featuring fully dynamic direct and indirect illumination, cinematic-quality depth of field and motion blur, PBR assets, and procedural asset placement, Kite required astronomical amounts of power to render, and it was only TITAN X that could deliver when Epic were looking for a GPU to render Kite in real-time at GDC.
TITAN X is also primed and ready for DirectX 12, a new graphics API that will increase performance, enable the creation of more detailed worlds, and allow developers to create previously-impossible experiences. Imagine a strategy game with tens of thousands of individual units, a city builder with unparalleled simulations and AI, and worlds filled with thousands of buildings and objects, each uniquely textured. These possibilities and more await later this year.
Whether you’re exploring space in VR in Elite: Dangerous, robbing a bank in 4K in Battlefield Hardline, or prepping your system for future experiences, TITAN X has the performance and features to give you smooth, consistent frame rates, with industry-leading frame times. And if you somehow max out TITAN X, it’s compatible with 2-Way, 3-Way and 4-Way SLI, and forthcoming VR SLI modes where each GPU renders separate displays in VR headsets to improve performance and further reduce latency.
Specification:
- GeForce Titan X
- GPU: GeForce Titan X
- Core Base Clock: 1000MHz
- Core Boost Clock: 1075MHz
- Memory Clock: 7010MHz
- Memory Size: 12288MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 3072
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin & 1x 8-Pin
- 600W PSU Required
- 250W TDP
- Dimensions: L=282mm, W=110mm, H=43mm
- Warranty: 3yr
From £1,099.99 inc VAT.
ORDER NOW
HERE
Specification:
- GeForce Titan X
- CUDA Cores: 3072
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 600W PSU Required
- 250W TDP
- Warranty: 3yr
ORDER NOW
